focus rads???
Old Apr 19, 2009 | 10:37 PM
delterflier's Avatar
delterflier
Default focus rads???
ok was under the bonet earlyer and noticed that a part of my rad was haning down
now there has been no water loss and she dosent run hot so the good thing is no leaks
but i have two rads by the look of it,was told one was for my aircon???
so whitch one is whitch?
the front one is damaged 03 plate 1.8 16 v
and any ideas on a price?
cherrs pps
john
Old Apr 20, 2009 | 06:07 AM
delterflier
anyone got any ideas at all??
john
Old Apr 20, 2009 | 07:38 PM
RichieST's Avatar
RichieST
Air con rad sits in front if i remember right. The engine rad is the larger one of the two, and it will have 2 black rubber pipes attached to it, the air con rad will have smaller metal pipes.
If it is the air con rad, then if it isnt leaking then I would leave it alone, as it can be costly to replace. If it does start to leak then it isnt the end of the world.
Old Apr 21, 2009 | 05:30 PM
delterflier
cherrs mate ,not realy bothered bout the aircon never use it anyways lol
but if anyone has a replacment kicking about i will be interested( plus a nice exhaust back box as well )
john
Old Apr 21, 2009 | 05:39 PM
RichieST's Avatar
RichieST
You should use the air con mate, as there is oil in there which needs to circulate to lubricate the seals to keep it all leak free, if it starts to leak the a/c will stop working which will cost a bit to fix when it comes to selling the car on!!
Just a few minutes once a month is enough
Old Apr 21, 2009 | 08:45 PM
delterflier
gud point but does it not use fuel?
think i will just secure whats there and see how it goes.
will it efect the car if it starts leaking?
john
Old Apr 21, 2009 | 09:22 PM
RichieST's Avatar
RichieST
Well it is more fuel efficient to have the air con on when doing more than 40ish mph than the drag that is caused by the windows being open!
In the summer I use air con with the climate control all the time, and to be honest I never notice any decrease in MPG.
If it leaks it wont affect the car, however the gas is highly poisionous (its got cfc's in it) so not a good idea if its parked in a garage over night etc.
If it does leak out, moisture will get into the system over time which will knacker the insides of the pipes and the condenser, which isnt going to be cheap to repair!
Old Apr 21, 2009 | 11:06 PM
focusrsred's Avatar
focusrsred
r134a doesn't contain CFCs
Old Apr 22, 2009 | 05:28 PM
delterflier
cherrs for ur help im going to the garage in a bit will secure it as best i can.
roll on next week .....finaly get my project home so i can rip it to bits lol
john
Old Apr 22, 2009 | 07:57 PM
mercury grey minter's Avatar
mercury grey minter
Air con system don,t have radiators,they have condensers.Most manufactures use a dye in the 134a gas so if you do have a leek it,s easy to spot.
New radiator = Ł130
new condenser =Ł150
Air-con regas =Ł50
Condensor is in front of the radiator.
The cooling fins (ziz zag type paper )can work loose and hang down but as long as the cooling ducts are not damaged it should be fine.
Old Jun 30, 2009 | 01:34 PM
bill hong's Avatar
bill hong
Thanks for all your post, I have the same problem and now it has been sorted!
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
liamT74
Sep 23, 2015 10:24 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Ben26
Sep 3, 2015 07:55 PM
