focus estate Seal / chassis
Hi all, can anyone tell me if ford focus's.. mainly the estate versions half a casing to protect the seal / chassis? (its a 2001 car btw)
basically my dads managed to dent his rear nearside chassis just before the rear wheel at the bottom to the extent the rubber plug is now visable..
i was wondering is this just a casing that can be pushed back out or is their no protective casing and its just the chassis itsself (surely this cant be the case since a slight knock managed to bend it in a little?)
anyways if it is seperate how can i push it out? can you pull out the plug on the underside and get apply pressure somehow ? or am i just wasting my time asking this and go buy some filler and spray?
thanks
EDIT - Also his indicator wont self cancel, is this down to a indicator ring failing or is it electrical on focus's?
thanks
You are taking about the outer sill, it's not chassis, and can be straightened with skill.
The indicators use a mechanical reset, either ring has moved or switch has broken.
DixieTheKid
11
06-06-2020 11:20 AM
