Focus hesitation....
Old Feb 26, 2008 | 10:44 AM
cosrep's Avatar
cosrep
Default Focus hesitation....
My mate drives a 2002 1.6 and I thought I'd just ask about a problem he's having, sometimes when he's accelerating throught the gears it seems to hit a bit of hesitation and the engine check light will flash a few times then it will continue as normal....any idea's???
Old Feb 26, 2008 | 09:40 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
Coil pack is dying rapidly. Get it sorted sooner rather than later. A new one from Ford is about Ł70
While you're changing that, check the spark plug gaps as well. They should be 1mm but it's not uncommon for 'pre-gapped plugs' to be miles out.......it used to be 1.3mm a few but this caused a lot of coil pack failures so they changed to 1mm gaps.
Old Feb 28, 2008 | 09:07 AM
wirralphil's Avatar
wirralphil
gaps should be 0.7mm for the 1.6se
Old Feb 28, 2008 | 09:13 AM
richj's Avatar
richj
Yep, coil pack is packing in, just had the wifes 1.4 Focus coilpack replaced a few weeks ago.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
