Squeaky brakes
Old Aug 8, 2007 | 11:08 AM
cosworthgirl's Avatar
cosworthgirl
Default Squeaky brakes
Just recently fitted some new discs and pads to my focus rs and they squeak quite badly, anyone else have the same probs, if so have you managed to cure it?
Thanks
Old Aug 8, 2007 | 11:38 AM
bassboy's Avatar
bassboy
did u put any copper grease on the back of the pads? not the friction material side as it would make braking quite tricky
also did you clean the caliper from the brake dust
oh and what pads/disc combo did you use
bassboy
Old Aug 8, 2007 | 12:45 PM
cosworthgirl
Yes put copper grease on the backs and cleaned the calipers.
Got the pads from Graham Goode and discs came from my mate who works in a parts place they are genuine ones tho......
Old Aug 8, 2007 | 12:48 PM
AlexRS2782's Avatar
AlexRS2782
Give it a few miles and it may go away - when i fitted my AP 6 pots got slight squeal for approx 100miles but after that they were fine
Old Aug 8, 2007 | 01:28 PM
bassboy's Avatar
bassboy
go mad with a bit of brake cleaner spray and see if it helps...failing that...as alex said...give it a while and it might go away
bassboy
Old Aug 8, 2007 | 01:42 PM
cosworthgirl
ok will do, thanks for your help
Old Aug 8, 2007 | 09:20 PM
Lami's Avatar
Lami
A trait of the brembos im afraid.
Get some APs.....that should sort it I hope!!!!!!!
Old Aug 8, 2007 | 09:37 PM
monkey nutz's Avatar
monkey nutz
Mine does this all the time - drives me round the bend! Just turn your stereo up like I do!
Old Aug 9, 2007 | 10:49 PM
bassboy's Avatar
bassboy
strange though as mine have never squeeked since i owned the car
bassboy
Old Aug 10, 2007 | 01:07 PM
Big Man's Avatar
Big Man
Mine squeek like hell! Propper WRC style, same calipers as Evos but the FRS disks are 5mm bigger, and they do the same!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
