st170 gearbox
Old Jun 20, 2007 | 08:52 AM
bick888's Avatar
bick888
Default st170 gearbox
Will a ST170 gear box fit a 2.0l Focus??
If so is there much gain from doing it?
cheerz
Old Jun 21, 2007 | 01:15 PM
mark_h's Avatar
mark_h
Ford Freak
it will fit . but you would need the st170 flywheel and clutch
Old Jun 22, 2007 | 06:24 PM
bick888's Avatar
bick888
would there be much gain from this set up?
Old Jun 24, 2007 | 07:33 PM
mark_h's Avatar
mark_h
Ford Freak
i would say there would be but it will be minimal.
so for value for money i probs wouldnt bother
Old Jun 25, 2007 | 11:01 AM
watson's Avatar
watson
Does the ST170 not have a 6th speed?
Old Jun 25, 2007 | 06:16 PM
bick888's Avatar
bick888
yep it does
Old Jun 26, 2007 | 11:27 AM
watson's Avatar
watson
Would you not get a better fuel consumption then say if you where sat doing 70 on the motorway 6th will be a higher ratio then the standard 5th there for less revs needed to maintain that speed so better fuel consumption?
So it could well be worth it
Old Jul 5, 2007 | 12:10 AM
pdfbt40's Avatar
pdfbt40
I've just done this with my Ghia 2.0l.
You have to change everything from the crankshaft to the wheel hub/knuckle (exclusively) including gearlever and cables.
A few minor niggles as well such as clutch hydraulics, heater hoses, reverse switch.
Oh, also as the VSS reads the FD pinion rather than a dummy speedo drive gear, the speedo overreads x3. So you need a re-calibrator. I used a SpeedoHealer, but that needs some extra bits as its designed to work with motorcycles. According to the manufacturer cars are abnormal!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
