lowering a focus 50mm
Old May 28, 2007 | 09:59 AM
cpaul4's Avatar
cpaul4
Default lowering a focus 50mm
I have just fitted a pi 50mm lowering kit and its rubbing quite badly when going around tight corners on both left and right bends. i have also put the st 170 brakes on also. The car is on 17's does anyone know of any solutions.
Chris
Old May 29, 2007 | 03:42 PM
watson's Avatar
watson
Does it rub front or back?
Mines lowerd 60mm with 17" also have the ST170 brake setup
Mines sound as a pound but as i started doing trackdays
I invested in these
If you up rate your shockers your springs will not compress as quick there for less travel so no rubbing.
Old May 30, 2007 | 07:56 AM
johnathan's Avatar
johnathan
mines 50 on 17's.
same question as watson, tho if i was u id bin the pi, there nothing but problems. hated mine failed a few times, and now im on spax, and no probs at all
Old Jun 1, 2007 | 12:36 PM
watson's Avatar
watson
Looks like its PI springs then fella, never had a problem with any other make and i have fitted a fair few.
Old Jun 1, 2007 | 04:18 PM
mercer's Avatar
mercer
I had PI springs on my 1.6 focus and was lowered 35mm I think. Had no problems at all and thought they were fine. Had normal brake setup and was on 17's.
Mercer
Old Jun 1, 2007 | 07:35 PM
bassboy's Avatar
bassboy
nothing you can do really mate...mind u i suppose you can remove the inner arch guards...if you do that make sure you paint or underseal the inside of the arches...Ford REALLY were tight with the paint!
for example, mine is lowered about 60-70mm and catches now and again on the inner arches.. (FRS) i can live with it though and just dont fully lock it unless i have to
bassboy
Old Jun 2, 2007 | 11:23 AM
cpaul4's Avatar
cpaul4
thanks for the advice, i rolled the arches and seems to be no probs now, and yeh paint is only like 3 costs thick, selling the car now for something a lil faster.
155lee
Oct 27, 2015 04:55 AM
rogerxr3i
Sep 13, 2015 06:56 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
