focus st hubs
Old May 16, 2007 | 06:32 PM
cpaul4's Avatar
cpaul4
Default focus st hubs
When putting st callipers and disc on a lesser spec focus do i need just the knuckle, or do i need the whole hub assembly. Any help would be great.
Chris
Old May 17, 2007 | 08:36 AM
watson's Avatar
watson
The hub and the nuck is the same thing mate and yes you need it.
I changed mine 2 months ago you need disc's calipers and the hub then they fit right on. I have pics if need be
Old May 19, 2007 | 01:24 PM
spark_gap's Avatar
spark_gap
hi watson! where did u source ur brake upgrade? is it brembo?
Old May 20, 2007 | 10:58 AM
watson's Avatar
watson
I got the ST170 hubs from a breakers then got all the rest new from ford.
But i dont have the ST170 calipers i have the mondeo V6 ones with 300mm disc's
Old May 20, 2007 | 04:14 PM
spark_gap's Avatar
spark_gap
thank u sir for the input
btw, do u need to change the master cylinder if u upgrade to a substantially bigger brakes, say from a self-adjusting setup to a fixed caliper multipiston setup?
how about ABS?... do u need to modify settings?
Old May 21, 2007 | 08:22 AM
watson's Avatar
watson
No you dont have to change the master cylinder its fine, and for ABS, well my focus does not have it so thats where i cant help you.
The hubs have all the right holes fitting etc to swap the sensor over so that bit is easy, as for settings i dont have a clue. but i dont think it will affect it.
Old May 23, 2007 | 04:00 PM
spark_gap's Avatar
spark_gap
thanks again for the inputs... i just need to find a big brake kit then
Old May 23, 2007 | 07:34 PM
NUTS RuS's Avatar
NUTS RuS
See the text in my sig lol
Sierrasideways
Oct 8, 2015 06:37 PM
IainRS1700T
Sep 25, 2015 06:44 AM
yorkie92
Sep 6, 2015 05:34 PM
jc1989rs
Sep 5, 2015 08:09 PM
