back fire problems....
Old Apr 27, 2007 | 06:59 AM
jamesy131's Avatar
jamesy131
Default back fire problems....
Hi, ive been running a blue fin for a few months now and my FRS has been popping a little during deceleration. Ive been told that the blue fin will allow petrol into the engine when you take your foot off the pedal so i havent been too concerned unitl now. Yesterday i fitted a milltek de cat pipe and cat back system, during the test drive the car was backfiring much more and seemingly with more force judging by the noise. If any what damage is this likely to do to the turbo or other parts? And how do i cure it?
Thanks,
James
Old Apr 27, 2007 | 11:42 AM
Crowder's Avatar
Crowder
check the plugs! its running more boost and fuel now with the decat and bluefin!! upgrade to some denso itv22's! will do the trick and reset the ecu aswell.
Crowds.
Old Apr 27, 2007 | 12:17 PM
jamesy131's Avatar
jamesy131
i changed plugs not 1000 miles ago but i am using standard parts so ill order some of the denso ones you suggested and try them. I guess they burn hotter and therefore less fuel is exhausted through the system? Thanks for the tip!
James
Old Apr 27, 2007 | 04:18 PM
Crowder's Avatar
Crowder
yeh defo bin the motorcraft jobbies!
Old Apr 27, 2007 | 09:07 PM
zvhrst's Avatar
zvhrst
where do i get these denso plugs!!!
ive searched everywhere and people are only willing to supply me with ITV20's
i'm running NGK 'R's at the min
Old Apr 28, 2007 | 02:04 PM
Crowder's Avatar
Crowder
heres a link for them https://passionford.com/forum/viewto...ghlight=oilman
Old May 1, 2007 | 11:16 AM
Lami's Avatar
Lami
You running an atmos DV eg: Bailey DV26???
If so bin it and get a re-circ eg: DV30 or Forge DV006, problem solved
Old May 1, 2007 | 11:29 AM
zvhrst's Avatar
zvhrst
now not running, but melted
mint_s2
Sep 2, 2015 08:58 AM
ekjim
Aug 17, 2015 08:57 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
