splutters when on boost
Old Apr 10, 2007 | 01:56 PM
zvhrst's Avatar
zvhrst
Default splutters when on boost
any ideas??
when i plant it, it goes fine till boost hits near 1 bar then it splutters and holds back,
any 1 had this problem before??
managment light came on and plugged it in and it said clutch coastin switch inop, so reset that but still does it, and managment light not coming back on..
Old Apr 10, 2007 | 04:28 PM
FRS 3409's Avatar
FRS 3409
possibly an air leak on the boost hoses or knackered plugs.
have a nosey under the bonnet and check for any loose clamps or obvious problems
ian
Old Apr 10, 2007 | 05:30 PM
zippy144's Avatar
zippy144
Hi
Does it do it when hot or cold???
Mine does it when it is cold....
But i would suggest plugs or leads as it has been known for the spark to be blown out by the boost and hence the mis fire. I had a similar problem with mine but i have put some ITV 24 plugs in and it has been fine..
Regards
Tom aka Zippy
Old Apr 11, 2007 | 04:32 PM
zvhrst's Avatar
zvhrst
thanks for the advice
its stopd doing it now,
filled up at tesco earlier and it eventually gave up doing it, so i'm thinking i got some dodgy fuel
Old Apr 12, 2007 | 09:54 AM
zvhrst's Avatar
zvhrst
its doing it again ggggrrrrrrrrr,
might not have been fuel so going to change plugs and leads today when i get chance
Old Apr 12, 2007 | 05:25 PM
zippy144's Avatar
zippy144
Hi
I asume you are using high ocatne fuel???
Regards
Tom aka Zippy
Old Apr 13, 2007 | 12:06 PM
RickyLee53's Avatar
RickyLee53
I had this problem before its caused by reduced vacuum in the MAF, usually a side effect of "sock" filters.
Old Apr 16, 2007 | 08:05 AM
zvhrst's Avatar
zvhrst
lmao rick, where have u lot heard am using a sock as a fliter lmfao,
Hi
Regards
Tom aka Zippy
yes i am using high octane, usually shel optimax, but now and again tesco 99 ron,
havnt had chance to change plugs yet, any upgrade plugs recomended??
Old Apr 16, 2007 | 03:56 PM
zippy144's Avatar
zippy144
Hi
Get Denso ITV 22's or 24's, it depends on your stage of tune...
Regards
Tom aka Zippy
Old Apr 17, 2007 | 08:58 AM
zvhrst's Avatar
zvhrst
Originally Posted by zippy144
Hi
Regards
Tom aka Zippy
std apart from i aint running with any DV
Old Apr 19, 2007 | 09:01 AM
zvhrst's Avatar
zvhrst
FIXED!!
will put pic up later,
number 3 plug was barley existent,
now replaced runs sweet as a nut
Old Apr 19, 2007 | 09:28 AM
zvhrst's Avatar
zvhrst
Old Apr 19, 2007 | 09:52 AM
COCHYN's Avatar
COCHYN
Where has that piece of the plug gone? I assume its fallen out, I wouldn't push it much if I were you, if that section of the plug is still there, could cause a problem in the cylinder.
But then again, it may have crumbed in2 thousands of pieces and blown out the exhaust.
Old Apr 19, 2007 | 10:14 AM
zvhrst's Avatar
zvhrst
i checked bores before putting new plugs in,
nothing there and everything looked ok,
car runs better than ever, i'm thinking its been like it since i piked it up in feb
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
