low rolling roll reading
Old Jul 9, 2006 | 11:31 PM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
Default low rolling roll reading
here's a good one for ya, plant the throttle hits 22 psi then gradually tails off to 13 psi when it hits the limiter any clues why it's doing this as i had a pretty poor reading on the rolling road 244bhp, a year ago (before i put a tubular manifold and boost controller on) i got 245 bhp so i'm a little dissapointed
Old Jul 10, 2006 | 08:46 AM
kmrobertson3's Avatar
kmrobertson3
What car you got?
I suggest you need a better or bigger turbo that can hold boost all the way up the rev range. Sounds like you've increased the flow so much with manifold and mods that your turbo can no longer keep up with the demand.
New turbo time matie peeps
Old Jul 10, 2006 | 02:29 PM
JamesS2RS's Avatar
JamesS2RS
Depending on what car it is maybe a new activator if it's not holding boost
Cheers,
Jim
Old Jul 10, 2006 | 06:37 PM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
its an rs focus with 36000 miles on it
Old Jul 10, 2006 | 08:19 PM
kmrobertson3
Go for Primary Designs 330 bhp upgrade of standard turbo, I've just done mine and it now holds boost all the way. See the post marked "finished article". It will cost you about Ł1000 but worth every penny
Old Jul 23, 2006 | 11:08 PM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
thats great but does everyone have these problems with the boost controller? seems i've spent Ł300 to lose power?
Old Jul 23, 2006 | 11:27 PM
rhysRS's Avatar
rhysRS
I would think it's the actuator mate. Let us know either way
Old Jul 24, 2006 | 06:17 AM
kmrobertson3
Remember the cars ecu limits the boost to 1.3 bar with bluefin anyway.
Old Jul 24, 2006 | 08:05 PM
Rob M666SCC's Avatar
Rob M666SCC
Sounds like a weak actuator to me....
Old Jul 24, 2006 | 09:05 PM
rhysRS's Avatar
rhysRS
Come on!! Same as rob! How good am i?? LOL
Old Jul 25, 2006 | 06:58 AM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
but surely the boost controller would overcome this, it would be like pulling the pipe off the actuator?? wouldn't it? thus stopping the wastegate from opening
Old Jul 29, 2006 | 05:44 PM
rssteve's Avatar
rssteve
yeah sounds like the actuator may be leaking.
I only run max of 19 psi through my boost controller but it holds this all the way to the limiter in every gear. Could you be running too much boost maby and the turbo can't produce it so it slowly backs off.
Old Jul 29, 2006 | 06:55 PM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
i've tried running it lower boost but it still backs off, ordered a better actuator from woodford there getting back to me on monday, looks a sod to fit though
Old Jul 30, 2006 | 08:39 AM
kmrobertson3
When I sent my turbo to Turbo Dynamics they fitted an uprated 1bar actuator.
Old Aug 1, 2006 | 10:00 PM
NathR's Avatar
NathR
Shouldn't be the controller, my Blitz peaks at 21psi and only drops 1-2 to the end of the rev range.
Old Aug 2, 2006 | 02:28 AM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
i must be blaming that cos you can see the graph tail off, probably did it before but didn't notice it
Old Aug 2, 2006 | 10:49 AM
Crowder's Avatar
Crowder
mines doing the same russ, i've been keeping an eye on it. goes to 21ish then will drop right off too 12/14. New actuator time i think!
Crowds.
Old Aug 2, 2006 | 09:41 PM
rssteve's Avatar
rssteve
maby its the 25psi boost your both running knackering your turbos. mines fine at the mo.
Old Aug 3, 2006 | 02:29 AM
ru51wrc's Avatar
ru51wrc
not loving 12 mpg!
oh well! bigger turbo then lol
Old Aug 3, 2006 | 05:03 PM
Focus_RS1658's Avatar
Focus_RS1658
What gain settings you using on your blitz controllers?
If you have it too high it can knacker the actuator and cause the boost to tail off quicker.. Think you could have a dodgey MAF sensor too with only 245Bhp
I have my Gain@15 & Ratio@72 for channel 4 holds 23psi to the redline in 5th gear. 3rd & 4th gear peaks 23psi & holds 21psi to the redline
Old Aug 3, 2006 | 06:03 PM
Crowder's Avatar
Crowder
yeh that could be it my gains at about 28 and boost is at 88 lol
Old Aug 3, 2006 | 07:41 PM
NathR's Avatar
NathR
There's a surprise!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
boeb
Jan 9, 2020 05:11 AM
timsrs
Nov 13, 2018 11:48 AM
Mikersturbo
Sep 27, 2015 07:43 PM
