Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
wipers stopped but motor still going?
Old May 7, 2014 | 12:41 PM
anthony lea's Avatar
anthony lea
Ford allegiance
Default wipers stopped but motor still going?
Driving earlier in the rain and wipers suddenly stopped. Thought it would be a fuse but once i pulled up i could see the motor was still working?
Before i start stripping it down is this a common fault and has simply separated at a ball joint?
Cheers!
Old May 7, 2014 | 12:52 PM
Siggi_Sierra's Avatar
Siggi_Sierra
Very likely broken ball joint like you say. Nothing else that can be the problem if the motor is still running. Best to put new bracket, but if your out of money you can also drill through the ball joint and put a bolt in the hole if the bracket is loose and not stiff.
Old May 7, 2014 | 02:00 PM
anthony lea
Ford allegiance
Ok mate cheers. I will charge my drill whilst taking the bits off incase i can salvage something for now
Old May 7, 2014 | 02:55 PM
ianmexico's Avatar
ianmexico
Had this happen with my connect and it was just the linkage underthe scuttle pane, that came loose so just had to tighten it up and sorted
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
bobsworth
77
Mar 24, 2016 09:30 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
