Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
subtle stutter at warm idle on focus
Old 17-07-2013, 01:11 PM
rusty459
rusty459's Avatar
Unhappy subtle stutter at warm idle on focus
Hi, my first post,
I have a 2001 black top se 1.6 focus petrol
i am experiencing a subtle stutter at idle
the rpm needle seems relatively level but it stutters and makes a slight resonating/wobbling noise; only at warm with the a/c off, if i turn a/c on it goes away when under load...
it idles at 700/800rpm when warm. there are no DTC in dash stored.
the vacuum hose was replaced as found to be split behind manifold, i run it on v power fuel with an aftermarket induction kit but it was doing this before changing the air filter..
the plugs are dry and clean, and it has not got the maf sensor, just a map sensor.
it's not perfomance hindering but irritating and relatively noisey when idling
no other symptoms!! the only thing i'm yet to do is an ECU reset. any suggestions please? (sorry if i have not posted this in the correct section entirely.. but i have searched high and low and cannot find anything like this on the internet)
thanks in advance
Old 19-07-2013, 12:41 PM
rusty459
rusty459's Avatar
Talking
update: to explain the noise is a light popping noise through the air filter which some people have experienced already.... however... new genuine plugs and a OE equivalent of leads has cured the problem!
-an ECU fuel/air trim reset has also been carried out through removing the battery for half an hour.. seems to have worked a treat. hope this helps those for future reference.
TPM961
15-01-2018 10:50 AM
RSmark84
13-09-2015 01:29 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
stevierob
07-09-2015 07:09 PM
routemaster
07-09-2015 05:27 PM
Quick Reply: subtle stutter at warm idle on focus
