Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Smoking and missing tddi engine
Old May 10, 2013 | 05:02 PM
iancott's Avatar
iancott
Default Smoking and missing tddi engine
Could anyone tell me the problem i could be having, i started my Ford Focus diesel 2001 model, it started ok but as i drove of the car lost power and sounded like it was missing, i noticed through my rear view mirror is was blowing alot of blue smoke, then the car stalled, i got it towed home and it started ok plus idles fine, but when i rev it there is alot of blue and white smoke and sounds like it is missing still , i have checked to see if the head gasket had gone but seems fine, any help will be great. Ian
Old May 10, 2013 | 10:20 PM
Csm's Avatar
Csm
Is the engine sounding like it is chuffing on tickover under the bonnet ??
Injector seals could need replacing, or an injector itself
Old May 11, 2013 | 01:13 PM
iancott's Avatar
iancott
Thanks for your reply, it sounds to tick over normal but when i rev it i would say it wants to rev up but blows alot of blue and white smoke out, i have backed of each injector in turn and the engine drops down in running then i tighten it up and picks up. Ian
Old May 11, 2013 | 01:15 PM
RichieST's Avatar
RichieST
Have you checked the timing?
Old May 11, 2013 | 01:26 PM
iancott's Avatar
iancott
No i have not done that, could it be the pump !!!! Ian
Old May 11, 2013 | 01:39 PM
RichieST's Avatar
RichieST
It could be, blue smoke would indicate oil is being burnt though, if the smoke is black I would suggest it's fuel related.
Old May 11, 2013 | 01:52 PM
iancott's Avatar
iancott
It is blue smoke and lots when i rev it, if is was fuel it would be black i think, there is no white smoke or head gasket signs or water loss, i think could the head gasket have blown in between the oil ways and the cylinders where oil is leaking in. Ian
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
SteveyDee
Aug 24, 2015 05:43 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
