Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
central locking
Old Feb 10, 2021 | 05:53 PM
johnno23's Avatar
johnno23
10 Year Member
Default central locking
Hi everyone, does anyone on the forum have any idea as to why now the cold weather has arrived my central locking has started to play up. When the temp drops to zero it works fine, however when it goes one degree or more below the system will unlock the car from the fob, enter the car sit down and the door latch will not engage in the lock. I have to leave engine running for several minutes to warm the interior before system starts to operate.so that I can close the door. My car is a focus 2.5 2008 1.6.
Thanks in advance,
Johnno
Old Feb 10, 2021 | 11:16 PM
Thrush's Avatar
Thrush
Irritating c........
Probably a voltage thing (assuming the latch engages the lock electronically rather than mechanically). My Lexus does weird things with its locks when the voltage drops, usually when it's sat a couple days without use and in the cold too, like I'll unlock it and then after I turn the ignition on (before starting) it will randomly fire the lock solenoids a few times for no apparent reason.
Old Feb 11, 2021 | 06:02 PM
johnno23's Avatar
johnno23
10 Year Member
Hi Thrush, thanks for reply, yeah the latch isn,t engaging manually or electronicaly. The door remains open even tho you can hear the central locking operating when the fob is pressed. The latch itself can be moved easily with a finger so that isn,t the problem. Looks like it seems to be a solenoid issue.
ermir
May 17, 2012 02:26 PM
ukste1349
Ford Focus RS
Feb 11, 2010 06:20 AM
DMR
Ford Focus RS
Dec 9, 2009 11:44 AM
atti
Jul 11, 2009 06:30 PM
