Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus 1.6 OBD Code P0352 running on 2 cylinders
Old May 7, 2014 | 07:12 PM
  #41
ShayneG's Avatar
ShayneG
Hi all,
Thanks for your help with this issue and it was most appreciated.
It turned out to be the ECU as suspected and as you guys have already said I'm guessing it's the driver circuit for the coil.
I changed the ECU for one I bought of ebay and it fired straight up and is now firing on all 4 cylinders.
For anyone else who has this issue, I just changed the ECU and coil pack (£60 from ebay) and as advised changed the transponder chip over in the key and it worked fine.
I did try the ECU on it's own to start at it worked fine so definatly that caused the issue, I fitted the genuine Ford coil pack as well just in case
Thanks again
Shayne
Old Feb 24, 2021 | 08:01 PM
  #42
GVK.'s Avatar
GVK.
bump...
yingus
Ford Focus Range
Apr 26, 2013 09:23 PM
Sonic Boom
Sep 14, 2011 04:00 PM
PGT
11
Jan 26, 2009 09:15 PM
barry0777
Feb 24, 2006 12:57 PM
James
12
Dec 7, 2005 06:50 PM
