Ford Focus (All Models)This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
I did the same a few years back for a customer who wanted the CCFL angel eyes installed in his 1.5 focus, came out well. I even fitted the clear indicator lens too.
I do the same to the Mondeo MK2 & MK3's, I must of done over 100 sets now with angel eyes and sometimes blackeyed too.
You need to get the plug and a good length of wiring off a scrap facelift mk1.5 focus
Then basically its cut the plug off your mk1, as close to the plug as possible leaving lots of loom and get as much loom as you can with the headlight plug you get off the scrap car, then its just a case of matching the colours up.
Mk1 Wire Colours
Near Side:
Main Beam - green/black
Direction Indicator - blue/orange
Headlight Levelling - blue
Direction Indicator Earth - black
Dipped Beam - green/orange
Sidelight - orange/blue
Main Earth - black
Offside:
Main Beam - green/orange
Headlight Levelling - blue/red
Dipped Beam - green/white
Sidelight - orange/green
Main Earth - black
Mk1.5 Wire Colours
Near Side:
Direction Indicator Earth - black/Yellow
Main Earth - black
Offside:
Direction Indicator Earth - black/Blue
Main Earth - black
As you can see most of the colours are the same, the only thing you have to watch is the orange and green wires, i wired mine up and the sidelight on the drivers side wouldnt work, the fuse was fine, everything, there is 2 orange and white wires on the drivers side headlight, one for sidelight, one for main beam, id got them wrong way round switched them over and it worked fine.
All the wires are the same so its just match the colours up, apart from the indicator wires they are different on each side, but just follow the guide as above and match the colours to the corresponding function on the headlights.
I just spade connected mine, depends how fussy you are with your car, if you do decide to spade/bullet connect them id put some vaseline on the connections and then insulation tape them up
Hey names richard new here i have wired these up but how. Come the self ajusting level dosent work ??
Mk1 Wire Colours
Near Side:
Main Earth - black
Offside:
Main Earth - black
Mk1.5 Wire Colours
Near Side:
Main Earth - black
Offside:
Main Earth - black
Hey ive tried to wored these up but the self leveling dosent work any clues ???
Motor is fine but just dosent auto level
Wires i used as in pic this is drivers side one
does look good for very little effort.
mark
hi i have just bought a set of st170 factory firred zeons from a scrap focus ...however after the seller saying they were plug n play when i fitted them only the indicators worked nothing else so i guess i have to hard wire them somehow ..there are 4 green wires going into a thick white connector one side and the other side theres 1 red wire ..1 black wire and 1 brown wire ..any help how to wire them up would be greatly appriciated
