Hello peeps, I would like some help identifying these objects on a ford fiesta mk6 engine. If you can help, that would be awesome and you would be doing your bit in the helping to make a project with adding a supercharger to an engine come into fruition
, oh thank you muchly
What is hole A?
:Does it contain a tap within, can it be used to put a threaded bolt into it?
:If it has no thread within can it be tapped with a tap, to be able to fix a bolt to it?
What is the part B?
:Self explanatory title here, what is the specific part? Is it the power steering pump?
:If you know what the part is can you give an oem part number for this please, so I can check just how it fixes to the rear of the engine block?
What is hole A?
What is the part B?
