Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Fiesta rear wiper missing area of glass
Old 14-09-2017, 07:11 PM
thebigbowler
thebigbowler's Avatar
Default Fiesta rear wiper missing area of glass
My fiesta mk6 has the thin metal wiper arm on the rear screen, it misses both the first few inches of coverage, and the last. At rest position the blade isn't making contact with the glass.
Can I tighten, adjust anything? Or is it a case of Bending it and hoping for the best?
Old 19-09-2017, 08:10 PM
chris cdti
chris cdti's Avatar
The pivot joint on the arm will have slight corrosion on it. Spray some wd40 etc on the joint and work the wiper arm away from the glass like when your replacing the blade and back to the glass again. Do this a few times to free it off and it will clear all the glass again. My old mk6.5 ST used to do it all the time.
Old 20-09-2017, 08:58 PM
thebigbowler
Thanks chris. Will have a go with that then.
Old 26-09-2017, 07:45 PM
thebigbowler
Worked a treat mate. Can't get a cheaper or easier fix than that!
thebigbowler
14-09-2017 07:10 PM
Quick Reply: Fiesta rear wiper missing area of glass
