HOW RELIABLE IS URS
Old 20-01-2006 | 05:04 PM
COSSIE 1's Avatar
COSSIE 1
Default HOW RELIABLE IS URS
Ive been scanning through the rs turbo section and ive come to the conclusion that rs turbos are very unreliable especially starting in the morning,when hot,blowing up, generally not starting..... , is this true.....how reliable woud u say urs is???? ive just bought one and im not looking forward to the future, should i worry?? ..cheers
Old 20-01-2006 | 05:31 PM
AKRS1's Avatar
AKRS1
dont forget mate they are getting older 15 years being the youngest model now but generally if you maintain it and look after it doing a oil change frequently it will be okay.
Old 20-01-2006 | 05:37 PM
Chris69's Avatar
Chris69
imo, (i've only been an rs owner for a couple of weeks so i'm new to rsts like u)
they can be reliable if u spend plenty of money on them so that everything is working on them right if not replaced with new parts.
I think aslong as u maintain them to a high standard and don't run silly amounts of power the'll see u good.
if u've just bought one i reccommend the first thing u do is get it serviced then visit a rr, it'll cost you around £100 for the rr tune but the operator will be able to point out any probs or weaknesses in ur car
scort19's Avatar
scort19
had mine for 2 month took it off the road to day as the bottom end has started knocking so the restoration has started earlier than i thought
Old 20-01-2006 | 05:46 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Reliability? Depends on what you call reliable. To me, reliable is a car that I know will start everytime, and get me home.
I bought my car when it was standard 5 years ago, and back then I never had any major problems that you wouldn't expect on a car of that age. It never let me down once I replaced the knackered battery and a couple of other worn parts soon after I got it. If you keep on top of minor maintainence you won't have a problem.
If your idea of reliable is a car that will run and run forever without doing anything to it, keep dreaming. And if your modified RST keeps blowing gearboxes or something because of the mods carried out, then that is your fault. Ford never built the car to run masses of power. So you can't complain.
That's how I look at it anyway
Old 20-01-2006 | 06:00 PM
addiction's Avatar
addiction
i trust mine 110%
Old 20-01-2006 | 06:27 PM
scortgti's Avatar
scortgti
mines the same as tony's(just nowhere near as nice) never given me any major problems.
Old 20-01-2006 | 06:32 PM
creedy's Avatar
creedy
id say the same as tony.
and if you look after it and service it, then it should be ok.
"love ur car and it will love u"
Old 20-01-2006 | 06:57 PM
zippyobrien's Avatar
zippyobrien
one of mine has vever let me down (its standard , bar a zorst and filter)
my other one lets me down every time i use it (250bhp)
gotta say i like my standard tatty one better
Old 20-01-2006 | 07:32 PM
AKRS1's Avatar
AKRS1
another thing would be is that i would rather have solid bodywork then mechanically wise being ok. if something like a gearbox or engine lets go you could more easily get it fixed then replacing panels and do welding
Old 20-01-2006 | 08:59 PM
Rick's Avatar
Rick
Mine's all good
Old 20-01-2006 | 09:17 PM
dry's Avatar
dry
Mine's bob on. Starter motor and clutch cable in 13 months. Starts first time every time hot or cold. Lovin it
Old 20-01-2006 | 10:23 PM
sufsRS's Avatar
sufsRS
touch wood never had any problems with mine, i think if a car is well maintained setup properly etc you wont have problems, so basically make sure theirs no cause for a problem
Old 20-01-2006 | 11:39 PM
Combi_Chris's Avatar
Combi_Chris
i use mine daily in ALL weather , sometimes doing 300 miles round trips
ive had a couple of little things go wrong, but see above ^^^^^ i agree with what he said, if you dont use your car often or drive like miss daisy , you WILL get problems
Old 21-01-2006 | 12:03 AM
Ad4m RST's Avatar
Ad4m RST
as said, if looked after RST's are very reliable. People buy them, don't look after them, then rag the tits off them and expect them to start first time and never miss a beat.....
most cars would be unreliable in that case
Old 21-01-2006 | 09:25 AM
Oranoco's Avatar
Oranoco
Mine used to give me all sorts of grief. I then found SCC Performance who now look after the car and got it to it's current state. Bar a few minor niggly problems she has been very good. And I can't say I'm too gentle with her.
These are old cars at the end of the day so problems are to be expected
Old 21-01-2006 | 09:39 AM
sara's Avatar
sara
sara
my engine currently is out as im havin steel rods fitted but before that it was cock on i have never touched my rs turbo i get jamsport to do EVERYTHING therefore its sound as a pound
Old 21-01-2006 | 11:51 AM
Oranoco's Avatar
Oranoco
Yummy steel rods
They are on my shopping list but imminant house purchase may put that on the back burner for a while
Old 21-01-2006 | 12:04 PM
Sexy-RS's Avatar
Sexy-RS
My car has never let me down once
We have used a 2 rs turbo's for a run about for the last 2 years and they have alwys been spot on to never a problem
suppose it depends how ell looked after they are
Old 21-01-2006 | 12:19 PM
AJC's Avatar
AJC
i trust mine
Old 21-01-2006 | 04:43 PM
Badman38's Avatar
Badman38
Default Re: HOW RELIABLE IS URS
to make them reliable ie start everytime never break anything takes alot of money, decent management expertly mapped,high spec engine built with the right bits and a proper gearbox like a cts stage two plus.. if you are running 200bhp rs and have'nt invested wisely expect to break down at sometime
Old 21-01-2006 | 06:13 PM
DazC's Avatar
DazC
Tony is spot on!
Old 21-01-2006 | 06:48 PM
Micky's Avatar
Micky
Mines only used for track days,but it laps at 10 tenths for 98% of its time.It is 100% reliable all the time,everytime.The secret is parts are replaced before they break,you cannot skimp on any uprated car or it will let you down.Regards Micky
Indyrs
04-12-2022 01:39 PM
IainRS1700T
25-09-2015 07:44 AM
gcfcos
24
21-09-2015 05:26 PM
1300gt
07-09-2015 01:06 PM
Johnny Knoxville
41
24-08-2015 07:55 AM
Quick Reply: HOW RELIABLE IS URS
