Who using cossy Man?
Ive tried looking but I cannot find one with everything on it...
I need a complete list of parts that I will need and any mods that need doing.
I could really do with some help.
Thanks,
James
Thanks,
James
JamesS2RS
you been on oddkiddcreations??
he s got a downloadable spread sheet with all the parts and prices!
i ve done the conversion my self and so have a couple of me mates and it isnt hard!
Originally Posted by Davey8oy
JamesS2RS
The parts i have are: -
Loom Cosworth 2wd
ECU Cosworth 2wd
Throttle Body Cosworth 2wd
Ignition Amplifier
Fuel Regulator Cosworth
Injectors STD Cosworth 2wd / 4x4
Efi Inlet manifold Modified
Bit i no i need to buy
top sensor bracket & phase disc & sensor
Bottom sensor bracket & sensor
Alternator & bracket
Bottom pulley & trigger wheel
crank sensor
phase sonsor
Throttle Position Switch Cosworth 2wd / 4x4
Idle Valve Cosworth 2wd / 4x4
Is there anything else?
Jim
If u brought a complete cossy inletmanifold would it have theThrottle Position Switch and Idle Valve on it?
Jim
Jim
im doin this conversion at the moment and lets just say, theres bloody loads of bits u need to buy, more than u think, if ya gona do it properly ie no expense spared.
definetly go to jano at oddkidd creations for any advice
Russ Payne
25-09-2015 08:29 PM
