Revlimitet - on the MFI
Old 17-01-2006 | 12:26 PM
cabrst's Avatar
cabrst
Default Revlimitet - on the MFI
I have got a hold off how to change the revlimitet on the MFI setup..
But i don't know what it will change it to......
So is there anybody that knows.....
Here is the pic:
Old 17-01-2006 | 12:47 PM
Sexy-RS's Avatar
Sexy-RS
WTF Not something you want to mess about with yourself really if you want the rev limit raised get a tunner to do it
Old 17-01-2006 | 12:51 PM
sufsRS's Avatar
sufsRS
s above wtf you need to get fuelling ammended accordingly otherwise it will be pinking like fook up their
Old 17-01-2006 | 12:59 PM
cabrst's Avatar
cabrst
yes i know that...
but im after what it will change the revlimitet to..not on what it will do that i know
Old 17-01-2006 | 01:32 PM
doggydowg's Avatar
doggydowg
that capacitor raises rev limit to 7.2 k fitted it in my xr2 rst as it was cammd and had std fuel ecu.
my new rs has it done too all that happens when they chip your fuel ecu is that bit gets replaced get sumone who is good at soldering to do it
Old 17-01-2006 | 06:04 PM
zippyobrien's Avatar
zippyobrien
where can you get the new capacitor from?
Old 17-01-2006 | 06:09 PM
JamesS2RS's Avatar
JamesS2RS
I work for an electronics company i could prob get the caps for ya but if your not good @ soldering dont bother otherwise your fuck the pcb.
Jim
Old 17-01-2006 | 06:16 PM
zippyobrien
i should use a crayon when soldering lol, im not very good lol
Old 18-01-2006 | 05:37 AM
cabrst's Avatar
cabrst
Thanks
that was what i was after....
Do anybody knows if you can use others size capacitor to change the revlimit let say to aprox 6800 rpm..
Old 18-01-2006 | 10:11 AM
doggydowg's Avatar
doggydowg
i searchd long and hard and unless you are realy clued up with electrics and could work it out using sum electrical equasions or fancy paying a tuner a oner to chip it to your specifications then no
think std cuts in @ 6.5k which would be fine on std cam if you running big cam run 7.2k ecu and if running std change gear earlier as std cam and turbo your not gaining anything by staying in gear at them revs
Where are you based?
Old 18-01-2006 | 11:59 AM
Rick's Avatar
Rick
capacitors have a MASSIVE tolerance
Old 18-01-2006 | 12:49 PM
cabrst's Avatar
cabrst
just bin told that if you only change the fuelbox and don't run a chip ECU this mod will remove the revlimit...
But a big to thoe That help
Old 19-01-2006 | 10:54 AM
doggydowg's Avatar
doggydowg
yeah but then u can only run std boost so youl take a while getting to the new rev limit
think i could only run 10psi on one of my stds ecus.
i thought big cams and that are for rst,s running 14psi+
Old 20-01-2006 | 11:22 AM
Rick's Avatar
Rick
Nope. "Big" cams are irrelevant when it comes to boost
Old 20-01-2006 | 12:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Used to be a guy from turbosystems sold them on e bay.
Old 20-01-2006 | 03:19 PM
doggydowg's Avatar
doggydowg
my piper t2 285 cam kit was recomended for 14psi+ pritty sure ive read it sumwhere else aswell.
would be pritty lame running 1600 engine with lagy cam and low boost would take ages to get there
steve.rst
15-03-2016 09:01 AM
Chas
05-10-2015 08:13 PM
Shaunc
Escort Range
23-09-2015 07:00 AM
stevierob
07-09-2015 08:09 PM
EoinXR3
07-09-2015 06:44 AM
Quick Reply: Revlimitet - on the MFI
