slight oil in intercooler
Old 26-12-2005 | 04:32 PM
bassboy's Avatar
bassboy
Default slight oil in intercooler
hi peeps just wondering if having a bit of oil in the intercooler (from the KE system) is a good or a bad thing? i heard oil will cause a bit of a boost drop while on the other side i have heard its a good thing...
what are your views?
bassboy
Old 26-12-2005 | 05:03 PM
AJC's Avatar
AJC
i have a slight bit in mine
i beleive its the norm, dont be worried
but some one may correct me on this
Old 26-12-2005 | 05:04 PM
bassboy's Avatar
bassboy
im sure its normal to however will the cooler run more efficiently if the oil wasnt there?
bassboy
AJC's Avatar
AJC
most probably
Old 26-12-2005 | 05:12 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
So long as its not masses of oil, it should be fine, I dont think theres not an RST without oil in the charge carrier/intercooler
Old 26-12-2005 | 05:18 PM
bassboy's Avatar
bassboy
i thought having an aftermarket oil breather system sorts this?
bassboy
Old 26-12-2005 | 06:05 PM
Charlie Chalk
Unknown.
It should
I take it you have a breather?
Old 26-12-2005 | 07:18 PM
ballin's Avatar
ballin
unless the breather return to metering head is blocked then even some aftermarket breathers will still cause this....
its either that or turbo oil seals - but that would be quite noticeable!
Old 27-12-2005 | 05:18 PM
mercury grey minter's Avatar
mercury grey minter
SAME THING HAPPENED TO MINE ,DUMP VALVE WAS BLOWING OIL OVER ENGINE EVERYTIME IT DUMPED,FITTED BAILEY BREATHER KIT AND PROBLEM WAS SORTED.
Old 27-12-2005 | 06:05 PM
SafeChav's Avatar
SafeChav
ALL turbos seem to let a tiny bit of oil in the pipes, probably due to the nature of the oil seals, dont worry about it unless your doing your oil changs from the boost pipes lol
Old 27-12-2005 | 09:21 PM
bassboy's Avatar
bassboy
no probs peeps just was curious as im going to block off the part of the breather that goes to the metering unit and have the oil caught into a tank...when i do it ill clean everything out, all the pipes, tb, intercooler and see how it goes...
only doing the cheap mods till the zetec goes in lol
bassboy
Old 27-12-2005 | 10:55 PM
©hatter Box's Avatar
©hatter Box
lot of the time people dont change the small round breather top of the rocker cover thats y the oil starts to fill up
Old 27-12-2005 | 11:42 PM
SafeChav's Avatar
SafeChav
Little tip: Tar and glue remover for cleaning the pipes, works like magic!!
This is also true, the oil control filter, serviceable part but most people dont know this. If your fitting a catch tank u can remove it anyway, catch tank will be far better
Old 28-12-2005 | 07:34 AM
withamxr's Avatar
withamxr
i was told last month that this is a pointer to a worn bottom end when i had the car set up on my local rollers was also advised not to chip the car until i get it rebuilt i really want to chip it for more power but i dont want want to ruin it.
i have had a second opinion and have been told it would be fine to chip there is very little residue in the charge carrier.
thanks
Old 28-12-2005 | 10:39 AM
ballin's Avatar
ballin
withamxr they are kind of right.....heavy breathing can be due to worn rings hence an uprated breather can actually disguise a more serious issue.
Old 28-12-2005 | 10:48 AM
AKRS1's Avatar
AKRS1
my rst has no oil must be first!
Old 28-12-2005 | 02:00 PM
SafeChav's Avatar
SafeChav
withamxr
As mentioned if the rings are excessively worn then you will get oil in the breather system, from my knowledge however it is "noticeabley" heavier breathing with f*ckloads of oil coming through, realistically u shouldnt get any oil in there, perhaps a little.
Do you drive your car
Old 28-12-2005 | 05:11 PM
AKRS1's Avatar
AKRS1
Originally Posted by safechav
withamxr
yeah i do just has no oil didnt mean to be rude
155lee
27-10-2015 04:55 AM
IainRS1700T
25-09-2015 06:44 AM
simonmcf
22-09-2015 08:40 AM
3doorcozmess
20-09-2015 06:15 PM
The Enigma
12-09-2015 10:12 PM
Quick Reply: slight oil in intercooler
