why would my brake pedal go rock solid while driving ?
my car was spluttering just now , tried to stop, and the brake pedal was rock solid , has anyone got any idea why ?
even when i did stop, there was very little movement , maybe an inch or 2 , normally theres a LOT more. could it be servo / master cyl problems ?
ive just spent a lot of money on things to solve another problem, now i have this issue, any ideas people ? ?
yes seems ok , but also the car tried to die while driving too before by about 5 minutes , but i didnt try to brake then . i dont know what to do after i have got a new master cyl
If its a RST, then the problem with the splutering could be the same as whats causing your brake pedal to go firm, any air leaks on the ke-jet system will make the car run rough, and from the sound of it, you either have a dodgy vacuume pipe to the servo, or a buggered servo.
When the car is switched off pump the pedal a couple of times untill its solid, then whilst holding down the btrake pedal start the car, if the vacuume on the servo is working the pedal should drop/become easy to press.
If not you have a problem
its cossie mangement i have no jet tronic , and yes the pedal stays hard after doing the test you described, it does go down a little but not much......i know it needs a proper map for my car, and it might not be worth doing until i have a new servo BUT it was better than this , i had to have some work done and i have a new '' base map '' im going to look at the mappping and hopefully improve it a little to stop the spluttering as it didnt do that before , i know i shouldnt until i have a new servo , but even a slight improvement will be better !!, new servo is on the way
I have cossie management on my Series 1, and when it was first fitted i just used a standard ECU and 4x4 standard blue injectors, it didnt splutter at all, could be that you have a sensor fault somewhere, if you have an air leak on the car with cossie stuff on, it will cause the revs to rise.
Hope you sort it mate.
CrOwSoN15
10-09-2015 07:33 PM
andrewmctiernan
08-09-2015 03:05 PM
