whats that plug on the amal valve for ?
as above really, founf a plug missing so i plugged it back on, made no difference that i can tell of, also the lowest pipe on the amal is gone , is that ok ?
the wire is for the power to amal valve, if u notice no difference when unplugged your amal valve doesnt work, i ran mine with the pipe at the bottom disconnected, with the one in metering unit blocked up
The amal valve is a way to help boost rise quickly at the beginning of boost build up.
At lower boost levels the amal valve is powered by the ECU and the boost from the compressor diverted to the airbox, hence allowing the boost to build quickly. At a certain level the power is taken away and all boost will be going to the actuator.
Without amal valve boost would be going to the actuator from the start, the actuator spring will give way and start opening the waste gate a bit from the beginning of boost. In this manner it will take longer to build boost.
This of course applies to a standard set up. A -31 actuator with a much stronger spring than standard, will give way to the boost pressure later.
if u block the metering unit pipe from the metering unit, it will run better IMO,mine did, instead of just dumping the air back into the metering unit, with the pipe removed from the amal valve it will go into the air, just like running a 3 way bleed valve,
mine boosted up a bit quicker, and felt more solid, as long as u block the metering unit one off!
deathrider666
28-09-2015 06:12 PM
