S2 servo and master cylinder question....
Old 05-06-2005, 06:40 PM
bassboy
bassboy's Avatar
Default S2 servo and master cylinder question....
Hi all...was just wondering whether a G plate Orion Master cylinder and manifold will fit onto my S2 (removed ABS and ST170 front setup and rear disc conversion soon)?
The orion was a Non ABS model...was a 1.4 carb IIRC if that makes any difference...
reason i want to fit this is because of the reseviour for one and second i have a weak pedal feel and have to press the brake pedal twice before its solid and brakes kick in properly without nearly touching the floor....
do you think this will solve the problem?
also bled the brakes about 5 times since the brakes were fitted and there is not a single bubble coming through whatsoever
bassboy
Old 05-06-2005, 08:43 PM
adamS2RST
adamS2RST's Avatar
It seems lots of people are having this trouble at the mo, looks like I will be the same in a couple of weeks time....hmmmm
Old 05-06-2005, 09:03 PM
bassboy
bassboy's Avatar
yep know what u mean mate! thinking about switching to a pedal box if i keep the car!
bassboy
Old 06-06-2005, 04:35 PM
Johnny Knoxville
Johnny Knoxville's Avatar
How about a Mk5 fiesta master cylinder and servo as Me and zvhturbo have done the conversion and the pedal feels a hell of a lot better
Old 06-06-2005, 09:00 PM
bassboy
bassboy's Avatar
johnny was this a straight forward fit? any extra details please? shouldnt be a problem with rear discs as well would there?
bassboy
Old 06-06-2005, 09:23 PM
adamS2RST
adamS2RST's Avatar
Yea, I wouldn't mind doing this, u need to modify a bracket or make one tho dont you? iirc
Old 06-06-2005, 10:36 PM
bassboy
bassboy's Avatar
bassboy
Old 07-06-2005, 06:18 AM
Johnny Knoxville
Yes it has to be cut and welded.
You need to cut the brackes in half and weld the front part of the fiesta one to the back part of the ERST one, the best way is to make a jig so everything is in the right place.
Pic's and more details and on page 4 of zvhtubo's conversion on the restro & rebuild forum
01-11-2015 06:53 PM
muzzman1
30-09-2015 08:59 PM
Quick Reply: S2 servo and master cylinder question....
