Going to Attempt MFI - EFI Conversion.. Just Painted My Inlet!
Old 22-06-2015, 07:52 PM
tejy
tejy's Avatar
Default Going to Attempt MFI - EFI Conversion.. Just Painted My Inlet!
So guys I've bitten the bullet and gone for the EFI conversion and decided to scrap the MFI.
I've just painted up my EFI inlet it took me a few days but in the end it came out like this..
Looks blue but to the human eye its gloss black. Proper happy with the result.
Will be converting my MFI running escort to EFI in the next few weeks. Not looking forward to the wiring which will be the next stage but will be giving it a go!
Old 22-06-2015, 07:54 PM
fabian l-a
B Road Warrior
fabian l-a's Avatar
That looks absolutely beautiful! Top marks that man!
Old 22-06-2015, 07:55 PM
Dubs44
Dubs44's Avatar
looks really good mate
Old 22-06-2015, 08:13 PM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
That looks lovely mate!
Which EFI system are you going for, something brand new or an old Ford setup?
Old 22-06-2015, 08:36 PM
tejy
tejy's Avatar
For the time being going to keep it on standard OFAB, just to get it running and sort out all the issues ive been having on mfi
Old 23-06-2015, 02:30 PM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
You may find you have just as many issues with OFAB these days, be sure to check/test your loom and sensors etc. as best you can before installation, everything is still 20+ years old too.
Old 26-06-2015, 03:19 PM
Rob_DOHC
Rob_DOHC's Avatar
Is now a bad time to suggest using an escort RS Turbo cross over pipe? Looking great Tejy. Did you use 2K or rattle can?
Rob,
Old 26-06-2015, 08:07 PM
tejy
tejy's Avatar
Rob,
I've got a escort crossover pipe but will be selling the mfi inlet etc all together as they've been painted gloss black
Will be using a fiesta rocker cover with this crossover pipe so it will fit.. thats the plan anyway!
Used a rattle can for primer, base coat and lacquer from a spray gun and compressor
stripped the loom out yesterday will be giving the wiring a once over next week and attempt to fit it all in the coming weeks!
Old 26-06-2015, 10:04 PM
studabear
studabear's Avatar
Will the frst charge pipe clear the bonnet?
Old 26-06-2015, 11:50 PM
tejy
tejy's Avatar
I dont see why it wouldnt..
Old 27-06-2015, 05:15 AM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
His still CVH Stu.
Old 27-06-2015, 09:16 AM
Nosmonkey
Nosmonkey's Avatar
Rob,
Any particular reason for using an ERST one Rob? I've always thought the sharp turn on the FRST charge carrier vs. the radius curve on the escort one would hinder the airflow a bit.
Old 28-06-2015, 02:22 PM
Chas
Chas's Avatar
I have to ask ; what is the going rate for an EFI manifold these days and can it be made easily to work with other injectors and ECU setups?
Old 28-06-2015, 03:22 PM
studabear
studabear's Avatar
Big choice of injectors fit that manifold, pretty much any standalone management should be ok to configure to the inlet, you can get sensor bosses to convert to cossie type coolant and act sensors off oddkidd, good sensors to use as the data for them us easily found and the sensors are readily available from msd etc
Old 28-06-2015, 09:12 PM
Rob_DOHC
Rob_DOHC's Avatar
No big reason, I was just winding him up , but yes the FRST has a nasty 90 deg turn where as the ERST has a smoother radius. In reality it probably doesn't make a difference.
Rob,
Old 29-06-2015, 12:14 PM
mentalasanything
mentalasanything's Avatar
Yes, as my pic which tejy posted shows, it fits and clears.
Lee
Old 29-06-2015, 02:02 PM
marky_g
Fleet Manager
marky_g's Avatar
Looks nice! I want to pint my I let now where did you find the gaskets to rebuild it?
Old 29-06-2015, 02:05 PM
tejy
tejy's Avatar
Gaskets For Classics - 01908 366435
Cost me under a tenner. Shipping was more than the gaskets
Old 09-07-2015, 10:43 PM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
IMO Either pipe makes little difference when using the EFI inlet which is a terrible inlet full stop (just look at it! lol), if you are worried about optimal flow you would choose another inlet and pipework accordingly
As for old looms, I wouldn't recommend using one, I never do... But if people want the plug and play option that's their choice and at least using an OFAM ECU makes fault finding it faster
I have a car in at the moment that's been EFI converted using OFAC and the loom is a right mess, I've spent a good few hours just diagnosing and repairing it... In fact this is why the car is with me, the customer couldn't get it to run right after the conversion! lol
Being stuck in the past thinking MS is just poorly built home made management doesn't help anyone, same as flogging the dead Cossie management horse... Times change, things move on, you have to move with them!
Old 10-07-2015, 10:01 AM
Moderator
STeve's Avatar
Im sure tejy does not want any bickering between you guys on his thread, if you really want to debate the pros and cons of things I suggest you pick up the phone and talk to each other as neither of you are paid traders on this site.
thread cleaned
Rob_DOHC (10-07-2015)
Old 10-07-2015, 10:10 AM
Rob_DOHC
Rob_DOHC's Avatar
Done deal, apologies to Teji for the thread hijack.
STeve (10-07-2015)
Old 10-07-2015, 10:12 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
o shizzle sorry..... just replied too.
STeve (10-07-2015)
Old 10-07-2015, 10:14 AM
Moderator
STeve's Avatar
Thanks guys
Versus_Creations (10-07-2015)
Old 10-07-2015, 11:52 AM
Roscopeco
P8 Managed S1 with ALS
Roscopeco's Avatar
The bickering makes threads more interesting
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
Johnny Knoxville
30-09-2015 07:21 AM
rsguy
44
29-09-2015 03:29 PM
Quick Reply: Going to Attempt MFI - EFI Conversion.. Just Painted My Inlet!
