turning up the boost
hi folks just bought a 1990 s2,its got scorpion exhaust,k+n,front mount intercooler,new engine
the ecu is chipped,but is only running 8psi
how do i turn the boost up and to what safe level
do i have to turn fuel pressure,
any help or advise
any help or advise
U TURN THE BOOST UP BE SHORTING THE ROD ON THE ACTUATOR (TURN IT) BUT WOULD RECOMEND IT TAKE IT AND GET IT TUNED ON A ROLLING ROAD THEY WILL DO IT ALL FOR YA SAVES U BLOWING YA ENGINE
Best to find out what chip is in the ECU, this is the way to find out what boost the car could run and go to a tuner and have it set up properly.
Apart from that you could consider to mount a lambda sensor in the exhaust and wire up a air fuel gauge. Than you always know the mixture.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
