Fitting bailey breather with cossie management
02-01-2015, 06:40 PM
The posh are up!!!
How would I fit a bailey breather tank with cossie management? Pics would be good
02-01-2015, 06:49 PM
P8 Managed S1 with ALS
03-01-2015, 01:06 PM
They fit the same as on mfi, if you had the bailey connected to the metering unit vent that pipe to atmosphere.
03-01-2015, 08:41 PM
can fit it in nearly the same location..twist the bracket round a few degrees and bolt it to where top half of the inlet bolts on
08-01-2015, 06:09 PM
08-02-2015, 05:56 AM
Ask me a question!
Having them bolted to head as above causes a dip in the pipe under the throttle body which will eventually fill up with oil.
Then the breather wont breath and cause back pressure also smoke possibly through the turbo depending on age and condition of rear seal.
Ideally the higher the breather the better id say as in pic 1.
08-02-2015, 09:02 AM
Balls Deep!
Quote:
Originally Posted by
Roscopeco
Love the Paul Walker quote!
08-02-2015, 02:25 PM
The posh are up!!!
Jano I'll let you sort that when the S2 comes in to your place for your handy work!
09-02-2015, 08:02 AM
Ask me a question!
No probs. I have decent pipework for the job too.
JoeyBoyden
20
22-08-2015 03:23 PM
JoeyBoyden
18-08-2015 10:52 PM
gingerturbo
18-08-2015 07:58 PM
155lee
14-08-2015 11:21 AM
RsS2daz
14-08-2015 05:26 AM
