ST170 into Series One....
Old 10-04-2014, 09:09 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Default ST170 into Series One....
Evening
I want to fit an ST170 engine into my Series One, keeping it naturally aspirated to begin with.
Does the engine bolt straight in and what gearbox options do I have?
1. Mk1 Focus RS
2. ST170 6 speed
3. RS Turbo
And what driveshafts are needed?
Apologies for the amount of questions, but tried searching with not much luck.
Cheers.
Old 11-04-2014, 04:25 PM
crazycage
crazycage's Avatar
You can fit any of the gearboxes you mentioned, I'd use a rst box then you don't need fancy mounts or shafts ect
Old 11-04-2014, 04:26 PM
homer j
homer j's Avatar
no richie it won't bolt straight in sadly. the alternator will be in the way of the existing engine mount for a start and the st170 will need fabrication to allow it to marry up with the inner wing.
if you can find a good focus rs box i'd use that but the nearside inner wing will need modifying to give enough clearance. st170 box will mean a flywheel change eventually as the dual mass one won't deal with revs or power very well. an rs turbo box can be used but you'll run into the usual power related bearing failures if forced inducted later on.
regards
Tom
Old 11-04-2014, 05:26 PM
rhinopower
rhinopower's Avatar
ib5 gearbox with erst lsd. uses standard driveshafts too. I've pm'd you.
Old 11-04-2014, 07:28 PM
studabear
studabear's Avatar
regards
Tom
The standard cvh mount can be modified. Move the alternator to the front like on the cvh.
Old 11-04-2014, 07:36 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Thanks for the info/answers
It will never be turbo'd so I guess the rst/ib5 option is easiest. Are they the same box?
Is the alternator moved using standard brackets or do I need a custom one?
Old 11-04-2014, 07:47 PM
studabear
studabear's Avatar
A drop bracket to lower the erst bracket further down the engine.
ib5 is a better box than the bc box.
They go very well turbo'd my engine is st170 based.
Old 11-04-2014, 07:52 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Any ideas where to get one?
I take it rst box is BC ?
I'm firm it's saying n/a, got enough turbo troubles as it is
Old 11-04-2014, 08:26 PM
studabear
studabear's Avatar
seller csgwheels on ebay
Yes
S1 aint a S1 without a blower
Old 11-04-2014, 08:28 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
How about a supercharger
arkeye
Ford Focus ST
20-02-2016 01:22 PM
AJC
08-10-2015 11:09 AM
Kiran1600E
11
02-10-2015 11:35 AM
muz
30-09-2015 08:29 AM
SMILER258
28-09-2015 09:04 AM
Quick Reply: ST170 into Series One....
