anyone on here using fixed or adjustable top mounts ?
Old 10-03-2014, 05:45 PM
s1cab
s1cab's Avatar
Default anyone on here using fixed or adjustable top mounts ?
Anybody got any pic's of top mounts fitted ? Which makes are good etc I'm thinking of getting compbrake fixed top mounts
Old 10-03-2014, 05:51 PM
stuart collins
stuart collins's Avatar
Yep , got comp brake on both of mine
Old 10-03-2014, 06:01 PM
JOHNDQ
JOHNDQ's Avatar
whats the max camber on them
Old 10-03-2014, 06:48 PM
s1cab
s1cab's Avatar
Do they go underneath the strut tops and then secure from above with 2 bolts ? Do you have any pic's mate ?
Old 10-03-2014, 07:11 PM
muz
Wye Valley Hardcore
muz's Avatar
Yeah, mine are the two bolt set up
Old 10-03-2014, 07:13 PM
s1cab
s1cab's Avatar
Cheers mate !
Old 10-03-2014, 11:57 PM
jonny s2
jonny s2's Avatar
i got the comp brake roller bearing jobbies too..... you can feel the difference
Old 11-03-2014, 06:44 PM
essexRSTSouthend
essexRSTSouthend's Avatar
always wondered about these too. Didn't know if it was ott or not..
Old 11-03-2014, 07:52 PM
s1cab
s1cab's Avatar
Which way round do the sleeve nuts go ? Ones longer than the other ?
Old 11-03-2014, 10:15 PM
muz
Wye Valley Hardcore
muz's Avatar
To attatch the shock? Mine are both the same length.
Old 12-03-2014, 08:09 AM
gus
gus's Avatar
I'm sure mine are too
Old 12-03-2014, 08:29 AM
s1cab
s1cab's Avatar
I'll put a pic up later one is longer
Old 12-03-2014, 03:19 PM
s1cab
s1cab's Avatar
I would say the longer threaded sleeve would go at the bottom ?
anyone on here using fixed or adjustable top mounts ?-forumrunner_20140312_151855.jpg
Old 12-03-2014, 03:20 PM
s1cab
s1cab's Avatar
And i do away with the bush underneath the strut as it is atm ?
Old 12-03-2014, 04:04 PM
muz
Wye Valley Hardcore
muz's Avatar
The smaller bush goes underneath as a reducer spacer and the longer threaded insert goes through the top.
Old 13-03-2014, 06:18 PM
s1cab
s1cab's Avatar
I don't need the bushes anymore then ? so the coilover's will just be solid onto the top mount ? Just never had them before and want to be sure.
thanks
Old 13-03-2014, 06:25 PM
muz
Wye Valley Hardcore
muz's Avatar
Yeah, ditch the rubber completely.
Old 13-03-2014, 06:47 PM
s1cab
s1cab's Avatar
Cheers for that ! Will be fitting them this weekend. Just going to take my time on drilling the two holes through the strut top, make sure they are perfect before drilling
Old 13-03-2014, 07:18 PM
jonny s2
jonny s2's Avatar
as muz says ditch the rubber. when you take it out you will see the difference
Old 19-03-2014, 07:28 PM
s1cab
s1cab's Avatar
Is this the correct order to put these on ? I do keep the metal domed bit that sits on top of the spring don't I ?
Old 20-03-2014, 08:04 AM
muz
Wye Valley Hardcore
muz's Avatar
Yes, you retain the black alloy top hat and do away with EVERYTHING Ford inc that bearing you still have on the shock.
Old 20-03-2014, 11:10 AM
s1cab
s1cab's Avatar
I remove both of these then ?
anyone on here using fixed or adjustable top mounts ?-forumrunner_20140320_111007.jpg
Old 20-03-2014, 07:42 PM
s1cab
s1cab's Avatar
So I don't use any of these .....
and it should now look like this ?
Old 21-03-2014, 10:35 AM
muz
Wye Valley Hardcore
muz's Avatar
Yep, that's it, mate.
Old 21-03-2014, 12:09 PM
s1cab
s1cab's Avatar
Thanks alot for your help mate much appreciated
jessie_rs
11
03-06-2019 04:57 PM
James Porter
28-10-2015 12:17 PM
yatta
01-09-2015 11:28 AM
FlashRS
13
31-08-2015 06:02 PM
dal3door
13-08-2015 06:55 AM
Quick Reply: anyone on here using fixed or adjustable top mounts ?
