Boost gauge reading?
Old Nov 22, 2013 | 08:05 PM
S2 Cabby's Avatar
S2 Cabby
Default Boost gauge reading?
Hi all I'm in the middle of doing loads of jobs on my s2 convertible and just wondered what other peoples boost gauge is reading on tickover? Thanks in advance
Old Nov 22, 2013 | 08:34 PM
Chopshop85's Avatar
Chopshop85
IIRC (its been a while since my car has been running) the guage sit around 18 InHg
I'll be honest, I have no idea what "InHg" is though.
Old Nov 22, 2013 | 09:46 PM
S2 Cabby's Avatar
S2 Cabby
Inhg I've never heard of that, mines in psi.
Old Nov 22, 2013 | 10:03 PM
Chopshop85's Avatar
Chopshop85
I've just googled it. Its about 8psi.
Old Nov 22, 2013 | 10:19 PM
S2 Cabby's Avatar
S2 Cabby
That's what it boosts too I take it, what about when it's just sitting on idle?
Old Nov 22, 2013 | 10:26 PM
botters's Avatar
botters
competant bodger
it should be sitting in vacuum not boost, vacuum is the inhg reading which not all gauges have, if your boost gauge starts at 0 and does not have negative readings then at idle it should show 0
Old Nov 22, 2013 | 10:46 PM
Chopshop85's Avatar
Chopshop85
That's the vacuum half of the boost gauge. So the below 0 part of the gauge. So 8psi of vacuum on idle.
Old Nov 23, 2013 | 11:45 AM
Karlos G's Avatar
Karlos G
Balls Deep!
InHg is inches of mercury, the greater the vacuum your creating at idle the better condition your engine is in and the less leaks you have on the intake side.
Old Nov 24, 2013 | 07:07 PM
S2 Cabby's Avatar
S2 Cabby
Excellent thanks for all the help
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
