cvh block
#41
Any high performance build block should be sonic mapped. Only then will you know if you have a sturdy starting point. All cast blocks have core shift (when the block was cast). For low power use probably not worth measuring. However, for extreme power builds (two or 3 times the power over stock) one should sonic map and select a block to use with minimal core shift and thick major thrust wall.
#43
Ben
That's all well and good if you have plenty to choose from, but they aren't exactly common place any more!
#45
A sleeved down Zetec block may be an option. Darton sleeves can be custom ordered.
I believe minimum sleeve thickness is 2.5mm. Thet being said going from 85 or 86mm Zetec to a 80mm 1.6 should work well.
I am not sure how cost effective this would be?
#58
If need be I can thickness test it for you, or if you van get it done local post the measurements ,I'll measure richies block when*I get back off holiday it's a S2 and split from one end to the other and crack big enough to get you finger nail in lol
#59
Export just the block - or block and crank? or block, crank and rods?
I assume purchasers in UK would want a cleaned and crack tested block.
Finding 1.9's is not too difficult. However, stripping them down, having blocks cleaned and crack tested starts to become costly.
A small container to ship to UK would have to be paid for too.
I am not sure UK persons would pay enough for 1.9 blocks to make it worthwhile (or even break even)
What would you pay for a bare 1.9 block?
#60
Irregular Poster
Im sure a tuner would buy say x 100 complete bottom ends and ship them. Then then could spec them to customers requirements and get their cut. You are happy, tuner happy, buyer happy - everyone's a winner baby!!! Lol
#61
Complete used bottom ends?
How does one guarantee them to be defect free without taking them apart?
Or are you saying completed built bottom ends?
#62
Irregular Poster
No as in buy engines and throw away the split port heads!! Just have from the deck to the sump complete, so tuners can mess around with with a few test blocks...mess around with cranks, cut blocks up to measure bore thicknesses etc. then the rest can be built accordingly, knowing what 1.9 cvhs are all about!!
#64
your dying to cut my engine into bits just to see whats happened in there
#66
The 1.9 is not stronger than the 1.6. The 1.9 at stock bore size is stronger than a bored out 1.6.
I would say that a 1.6 (at standard bore) with the shorter cylinder wall height is stronger for big power. But the 1.9 would allow for lower boost to make the same power as a 1.6 so who knows which would work better? I still suspect a stock bore 1.6 being the best starting point for high boost.
I have never measured the cylinder wall thickness of a zetec - so no comment there.
With a zetec you have the option of a CGI block for big power builds. (these are rare as hens teeth).
#68
Hello Crazy!
Did you measure major thrust, minor thrust and fore/aft?
Major thrust being left side of cylinder when looking at front of engine.(I am sure you already know this).
The 1.9 I measured (overbored 0.5mm) had 4.7 to 5.6mm thick major thrust
5.1 to 6.3mm minor thrust side.
Between the cylinder walls (non thrust) measured 3.4 to 4.0mm
I believe more room was left between cylinders for better water coolin
#72
If the 1900cvh is an option why not use an 1800cvh block and crank. I have one an it's performed great. I did a bit of research a few years back and read that the 1800 is basically a 1900 with smaller bores (not 100% on this)
Ferriday engineering built mine and has loads of info on them.
Ginger
Ginger
#73
Ben
#75
The shorter cylinder wall of the shorter 1.6 block will be able to stand more abuse if cylinder wall thickness is similar.
A bored out 1.6 (+2mm overbore) is certainly weaker than standard bore 1.9.
#76
Your rod broke first and destroyed the block as a result. Even CGI blocks will break when a connecting rod breaks.
#77
yes im aware of that !!! I belive a big end bolt let go .the rod actually went through the block and sump and left parts all over the road "!!! ive owned 11 rs turbos and never had a 1.6 cvh do this full stop .only the 1900 so personally I wouldnt touch one myself.
my zvh has made over 300bhp scince 2006 with no issues at all with my favourite cvh head attached to it![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
what were the systems 2 power and engineering 1905 cc engines years ago ???????????
#78
[QUOTE=zvh;6352539]yes im aware of that !!! I belive a big end bolt let go .the rod actually went through the block and sump and left parts all over the road "!!! ive owned 11 rs turbos and never had a 1.6 cvh do this full stop .only the 1900 so personally I wouldnt touch one myself.
what were the systems 2 power and engineering 1905 cc engines years ago ???????????[/QUOTE
I don't get your logic. You are aware that throwing a rod out of the side of a 1900 was not a result of a weak block. But you wouldn't touch a 1.9?
ZVH engines (same 88mm stroke as 1.9) use different connecting rods than the 1.9 tall block. Maybe (it is) the weak point in the 1.9 is the connecting rod/bolt. The longer stroke of the 1.9 would certainly make the bolt fail at a lower rpm than the 1.6 engines.
So - upgrade the connecting rods and pistons when using a 1.9 block. Steel rods and pistons are not that expensive these days.
#79
well no why would I want to buy a 1.9?? when my zvh with arrows rods and arias pistons has run over 300bhp and 398 lbft scince 2006 >>>>I have no need to touch one im very happy with my zetec block that has lasted as a daily driver and is still spot on now . that's why I wouldn't touch another 1.9 or a 1.6 either I have no need to . and it seams to me no matte how much power you push from the 1.6 they never produce they same torque figures as the zvh any way
