Quick one, removing engine
Old Aug 3, 2013 | 02:10 PM
StephenC's Avatar
StephenC
..BS Motorsport..
Default Quick one, removing engine
Can the block be removed with the gearbox in situ? (CVH)
Old Aug 3, 2013 | 02:13 PM
stuart collins's Avatar
stuart collins
yes It can
Old Aug 3, 2013 | 02:59 PM
Ben26's Avatar
Ben26
Yes it can. But take off the bottom pulley to clear the chassis leg. Loosen the gearbox mountd as well so it can tilt up as thats helps big time.
Old Aug 3, 2013 | 03:29 PM
GVK.'s Avatar
GVK.
I did a series 1 in the back yard years ago, I'd already got the head off as it cracked a piston, the block itself came out pretty easily. I put the block in on it's own and put the head on after, it's easier to do that, as you're not chasing the motor round and round to tighten the head bolts if you don't have an engine stand/someone helpful to hold it.
Old Aug 3, 2013 | 07:10 PM
StephenC's Avatar
StephenC
..BS Motorsport..
sweet, cheers gents. Gonna get the lump out and see what condition things are in.
Old Aug 3, 2013 | 09:00 PM
studabear's Avatar
studabear
if its a s2 and your dropping the block out the bottom then you wanna remove the anti roll bar first, I found out the first time I dropped 1 of mine out, struggled like hell and had to unbolt the clutch through the gap inorder to get it all out.
The next time I removed it I think I removed the bottom pulley, roll bar and it came out a treat.
(3cvh's in the bay last year)
Old Aug 3, 2013 | 09:06 PM
StephenC's Avatar
StephenC
..BS Motorsport..
ah, meant to say I was hoping to lift it out? will it go that way?
Old Aug 3, 2013 | 09:11 PM
studabear's Avatar
studabear
yeah it will lift out
Old Aug 3, 2013 | 09:17 PM
Gadget's Avatar
Gadget
Spanner monkey
yep, as others said, Bottom pulley off, and i jack the bell housing up to angle it up more to allow the engine to pull out easier.
can get the engine out very quickly this way.
matman
Sep 9, 2015 05:45 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
