fuel problem
Old Jun 19, 2013 | 05:23 AM
nevillersturbo's Avatar
nevillersturbo
Default fuel problem
mfi system.
firing on 3 cyllinders. 1,2,3 working but no fuel on number 4
changed injectors to brand new ones,checked fuel line for blockage and no blockage. removed pipe from metering head and when given safe starter no fuel was coming out.
any help?
Old Jun 19, 2013 | 01:47 PM
rsmark86's Avatar
rsmark86
If its coming out of the other 3, sounds like the metering unit is dead
Does it spark on all four cyclinders
Old Jun 19, 2013 | 02:22 PM
nevillersturbo
yes spark is on all four. infact the engine runs on 3 but very lumpy.
i was thinking that the metering head has gone so i changed it with another one, second hand and doing the same.no fuel coming out from no 4
then i must be unlucky on both of the metering uinits head.
Old Jun 19, 2013 | 02:27 PM
rsmark86's Avatar
rsmark86
Try the fuel ecu, I doubt 2 units would have the same problem
Old Jun 19, 2013 | 06:52 PM
Red_bull's Avatar
Red_bull
How did you check the line for blockage?
Old Jun 19, 2013 | 08:56 PM
rsmark86's Avatar
rsmark86
to check the lines i would just connect it too one of the other metering unit outlets and see if fuel comes through
or remove it and turn on ignition and see if fuel comes out the metering unit on that outlet with the injector hose removed
Old Jun 20, 2013 | 05:06 AM
XR2's Avatar
XR2
disconnect the pipe from the metering head and the injector and just blow through?
As it's a K-Jetronic (the K stands for kontinuierlich = continuous) all injectors will get the same amount of fuel at the same time. So you can connect the injector pipes to any ports of the metering head, it would make no difference. To make sure it's not the head itself just disconnect the not working pipe/injector and connect it to a different port.
Old Jun 20, 2013 | 01:27 PM
nevillersturbo
removed the pipes from the metering head and when gave safe starter only from 3 came out fuel.so the problem is from the metering head.
thanks alot guys
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
