bc box and puma shifter
as above anybody running this set up...picked a project up with this setup but engine was goosed so never got to drive it...put the lsd box in ma frst and deffo need to sort shifter out as frst standard 1 past its best...
so info needed on..do u noticed it doesnt correct itself and if so is it a pain in the ass or is it all good
cheers
cheers
Just add some neutral return springs. Not hard to do. Could even use the neutral spring as used on xr2's (uses the chassis rail and the linkage with a plastic hook to keep it returning - still available from ford for about £10).
Steve Escos
01-10-2015 06:57 AM
