Low compression
Old Jun 9, 2013 | 03:05 PM
turbobill's Avatar
turbobill
Default Low compression
Hello, been a while since ive posted on here,
Just bought a new rs and with a week of owning, the thermostat got stuck and popped the headgasket, so toook it all apart head skimmed, new bolts n headgasket, (all done correctly) and i done a compression test, startimg from the cambelt end, im getting 9 bar, 10 bar, 10 bar and 11 bar, seemed abit of a drop to me and headgasket had gone again, so took it all apart bought a new head and put back together, headgasket is all good, (so far) but still got same compression, it smokes a little to, so im wondering if its rings gone? Or something else? Ive changed valve stems aswell,
Sorry for long post and any help would be great, thanks bill
Old Jun 10, 2013 | 07:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If it's blue smoke (oil) then could be rings, blocked breathers, turbo or valve stem seals.
Your uneven compression isn't great and as you've changed the head it can really only be rings.
Old Jun 11, 2013 | 09:37 AM
turbobill's Avatar
turbobill
I had the same compression when i had my old head, got new head same compression, done a wet test on it last night and it raised compression, so defentily rings
Bottom end rebuild it is
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Tank Mike
Sep 26, 2015 08:07 AM
