Will it work? ??
Old May 21, 2013 | 10:39 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default Will it work? ??
Will using a xr2i loom work for a straight swap for efi conversion?
Old May 22, 2013 | 07:31 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Don't think you can use the xr2i loom mate
Old May 22, 2013 | 07:40 PM
RS 5tu's Avatar
RS 5tu
you cam use the engine loom, with some changes to run ofab or ofac
Old May 22, 2013 | 09:42 PM
Jamie_EscortSport
Have you any ideas of what needs adapting?
Old May 23, 2013 | 10:11 AM
Rob_DOHC's Avatar
Rob_DOHC
I'm fairly certain that the changes are with the map sensor wiring. RS bible has/had some good info about this. If you have a multimeter it wouldn't be hard to check your loom and make the changes.
Rob,
Old May 23, 2013 | 10:12 AM
Rob_DOHC's Avatar
Rob_DOHC
PS, the xr2i loom obviously won't have amal valve wiring either, but that wouldn't be such an issue if you were using an external form of boost control.
Old May 23, 2013 | 11:30 AM
rsmark86's Avatar
rsmark86
It's in the sticky on here, how to convert from mfi to efi
Old May 23, 2013 | 12:30 PM
Jamie_EscortSport
cheers rob i will have a look, yea will be using a MBC first off with external wastegate so it wont be needed.
From when i last read i thought that was for converting a xr3i loom, am i right in saying the xr2 n xr3 looms are different
Old May 23, 2013 | 03:42 PM
mk1trb's Avatar
mk1trb
Boost Junkie
2i loom with ofac is pretty much plug and play but the air temp sensor plug will need swapping for a turbo one, for ofab there will be pin changes which can be found on rs bible. do a search on here and im sure ull find something, its een covered plenty of times
Old May 23, 2013 | 05:40 PM
neil73's Avatar
neil73
There's a guide for changes needed to each of the different looms here
http://www.fiestaturbo.com/forums/gu...anges-vt77331/
Old May 23, 2013 | 08:52 PM
Rob_DOHC's Avatar
Rob_DOHC
All the info you could need The forum seems much friendlier these days, good to see every one helping each other again.
Rob,
Old May 23, 2013 | 09:26 PM
Jamie_EscortSport
Spot on guys cheers!
Old May 24, 2013 | 02:26 AM
darrenb16two's Avatar
darrenb16two
Rob,
It was getting stupidly bitchy. Silly really as we're all here for the same reason
Old May 25, 2013 | 11:44 PM
Rob_DOHC's Avatar
Rob_DOHC
Tell me about it lol, I haven't really logged on much recently because of it.
Old May 26, 2013 | 06:24 PM
rsmark86's Avatar
rsmark86
I went vauxhall because of it then realised they are total inbreds
Old May 26, 2013 | 10:11 PM
Rob_DOHC's Avatar
Rob_DOHC
Hahaha, you think the vaux forums are bad, you should try the bmw ones!
Rob,
Old May 27, 2013 | 12:32 AM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
What so bad about these other forums then ? Cliquey or just plain rude and unhelpful ?
Old May 27, 2013 | 02:26 PM
Rob_DOHC's Avatar
Rob_DOHC
Tbh I don't really use other forums that much, the bmw ones seem friendly enough just boring. All about cleaning this or paying bmw to change that. About a million posts about turbo conversions but no one doing them. Nothing really technically interesting like you get on here sometimes. I can't comment on the vaux forums tho.
Old May 27, 2013 | 02:39 PM
studabear's Avatar
studabear
passionford or the odd look on stoc, thats it for general car stuff for me.
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
