EDIS and Coilpack
Morning all,
I've finished my EFi conversion now and I'm trying to get the car started. I've only got 10v ignition live at the EDIS so I know I have a problem there but what should the voltage be on the coil outputs? I'm guessing that should be 12v too?
Cheers,
Lee
Cheers,
Lee
Ok, I've sorted it now. Had a bad earth to the EDIS module, a continuity test found that out. The EDIS should have 12v ignition live to pin 8 and should have earth to pin 9. All 3 pins on the coil harness should have positive 12v with the ignition on and the engine off. The edis switches the outer 2 pins to earth to fire the coil.
To test the coil, you should get about 3-6 Ohm resistance across the middle pin and one outer pin Of the coil loom connector and 13-16K Ohm across 2 common lead posts (I.e. 1&4 or 2&3)
Anyway, she's finally alive!
Lee
Lee
mk3ste
17-10-2021 10:09 AM
bigluke200
14
02-09-2015 10:35 PM
muz
16-08-2015 12:57 PM
marky_g
15-08-2015 10:43 AM
Jim Galbally
13-07-2005 10:25 PM
