hybird turbo
hybird turbo
hi all, i am looking for a little advice i am after a hybird for my rs but not sure where to go and how much it will cost? is it better to buy 2nd hand or new.
Tejy the Management is mirosqruit its efi and the bottom end 2l with forge pistons , the head is a fizzy turbo with newman can at the mo it running 215bhp..
Karlos i guess i am looking for around 250 to 265
Balls Deep!
Then it's an easy answer mate, for a 2.0L you need a stage 3 T3 (.48/55) at the very minimum! Anything less and you be strangling your engine at mid/high RPM and getting things very hot.
Second hand if you can know for 100% certain the spec of a turbo and there is minimal play in the shaft will save you a few quid but a new one will only be about £500 so I'd go new personally.... CR Turbo's, Turbo Techincs, etc.. etc..
JK12
33
26-04-2021 12:09 PM
