my issue im having.. help!!!
grayzo
right basically my escort s2 oil light comes on when the car is warm but goes off when u rev the car to around 2k revs. and also there is a rattle from the engine.
engine has done less than 2k miles..
ive checked the big ends and there is no scoring and all seems well.
could this be the oil pump not supplying the top end with oil
engine spec is
+1mm accralite pistons
farndon rods
apparently a high pressure oil pump from burtons
acl bearings
ive also checked the bores and they are perfect
also car does not smoke one bit even first start or over run
any help would be appreciated
engine spec is
farndon rods
acl bearings
I had the same problem and i used a high pressure oil pump like yours, i think a lot of people have had problems with them, something to do with the spring inside the pump? I got so frustrated trying to find the problem with mine i built a zvh instead lol
register an account on photobucket.com. Create a new album and upload your pictures onto there. Once they are uploaded if you hover your mouse over the picture a lil drop down box will appear copy the IMG link and paste it in the reply box on your thread. Hope that helps
SMILER258
28-09-2015 09:04 AM
