fixing bodykit back onto series 2
hi all
as above, whats the best double sided tape to use to fix the arch extensions back onto the rear of my S2 along with pop rivets.
anybody have any good tips and pictures of where the best place to fix the tape onto the arch
thanks
thanks
I have always found the best double sided tape is the 3m stuff you have to pay a little more for it bug if is by fad the best out there mate, I use if most days at work but you needs to make sure both surfaces are nice and clean otherwise you will just be wasting your time and money on the tape as it will not hold, I always put the tape on the part and then warm it up a little with a hot air gun which just helps it stick abit more pal
fuzzy
21
15-02-2016 10:26 PM
