s2- empty under normal load
Old Feb 25, 2013 | 12:37 PM
Marino's Avatar
Marino
Talking s2- empty under normal load
first of all sorry for my english, I'm Italian. I just finished restoring my s2 but I have a problem. if I stay at fixed rpm, the engine makes holes, is not regular. to a idle and full load is fine. I changed dizzy, sparks, metering unit, fuel injectors, fuel pump, coil. the engine is standard: normal pressure turbo, 12deg timing, idle CO at 1.5%.
I can not find the problem, I'm going crazy
Old Feb 25, 2013 | 04:45 PM
Marino's Avatar
Marino
nothing?
Old Feb 25, 2013 | 04:53 PM
RSmark84's Avatar
RSmark84
1st post makes no sense.
Old Feb 25, 2013 | 05:08 PM
Mr.T's Avatar
Mr.T
holes???
Old Feb 25, 2013 | 05:15 PM
RSmark84's Avatar
RSmark84
exactly the title makes no sense either, What is actually empty? Fuel, oil, water?
Why dont you type in Italian and use a translator to convert it to English?
Old Feb 25, 2013 | 05:20 PM
Think he means when holding a constant rev, the engine jumps ,i would advise the car having a proper set up
Old Feb 25, 2013 | 06:47 PM
Marino's Avatar
Marino
exactly Twins , what can I do to fix this?
PS: sorry, it is very difficult to translate technical words
Old Feb 25, 2013 | 07:03 PM
Mr.T's Avatar
Mr.T
that would be worse tbh. Translators suck
Old Feb 25, 2013 | 07:04 PM
Mr.T's Avatar
Mr.T
Maybe you should look for a boost or vacuum leak.
Old Feb 25, 2013 | 07:16 PM
Marino's Avatar
Marino
i checked the vacuum leak, but nothing. at idle and full load is fine.
i also tried to change the temperature coolant sensor and the thermo-switch. the problem goes away if retard a lot the ignition timing.
this information can help?
Old Feb 25, 2013 | 07:24 PM
RSmark84's Avatar
RSmark84
Yes it does. Get it set up.
Old Feb 25, 2013 | 07:39 PM
Marino's Avatar
Marino
i set up the ignition timing and the fuel mixture with the haynes manual
Old Feb 25, 2013 | 07:47 PM
RSmark84's Avatar
RSmark84
Just get it set up, it'll sort the problem out and the tuner will find anything wrong with the engine and fix it.
Don't mess around with the fueling yourself if you don't understand the Bosch unit.
Old Feb 25, 2013 | 08:41 PM
luxembourgrst's Avatar
luxembourgrst
is your pontiometre the sensor on the flap where you give throttle gaz there are 3 postion idle load full load
Old Feb 25, 2013 | 09:05 PM
theheap's Avatar
theheap
I think we're talking flat spots here fellas
Old Feb 25, 2013 | 09:06 PM
theheap's Avatar
theheap
Fuel pressure regulator
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
