Efi ecu position
Efi ecu position
Has any one mounted an EFI ecu on the bulk head where the MFI one is located? Im thinking about mounting mine there as i dont want to drill a hole in the bulk head if i dont have to.Any info would be appreciated thanks.
Thats what i was thinking,ive not heard of anyone doing it though.Most people ive spoke to just drill a hole and put it in the car.I dont really want to do that if i dont have to.I was going to make a 2 peice bracket to bolt onto the original ecu plate so its also easily removable. I was also going to weld an L shaped peice on the top of the original holder to make sure no water could get into it.The only thing that i can think might be a problem is the heat in the engine bay thats why im hoping someone has done it already and could advise me.
An eye for detail...
I imagine its probably due to maybe not having a sealed ecu case (havent checked an EFI case)? Or maybe cause of the shape of the loom they use?
Spanner monkey
I've just done an efi conversion on a series 2 and thought about mounting the ecu there but looking at the ecu, it isn't sealed like a series 2 one so i extended the wiring and mounted it in the glovebox in the original bracket allowing it to be removed easily still!
Like Gadget above says! The ofac/ofab isn't a sealed enclosure so has to be mounted in the car. I would highly recommend drilling the bulk head and painting the hole before fitting a nice grommet. The inside of the car is far FAR cooler than the engine bay in the escorts. Behind the gearstick is a good position or on top of the glove box (thats where mine is). You can use a standard ford bracket out of an XR3i to mount it.
Rob,
Rob,
