rev counter problem
Old Dec 17, 2012 | 10:50 PM
Skinny's Avatar
Skinny
Default rev counter problem
Hello people I've got a problem with my rev counter I've had the problem since I built my car just never got around to sorting it, the ptoblem I have is that on tick over it shows that its sitting at about 1600 rpm when it clearly isnt then when you drive it the needle shoots off the rev counter way past 7000 rpm when it clearly isnt revving that high.
Do any of you have a idea of what it could be?
cheers
Old Dec 17, 2012 | 10:57 PM
studabear's Avatar
studabear
efi clock on mfi car?
or knackered clock?
Old Dec 18, 2012 | 10:42 AM
Skinny's Avatar
Skinny
How can you tell the difference between efi and mfi clocks mate?
Old Dec 18, 2012 | 12:22 PM
martysmartie's Avatar
martysmartie
Easiest way is to tell us if your car is standard (MFI) or been converted to EFI? If the latter you will need to mod or replace the gauge.
Martin
Old Dec 18, 2012 | 02:55 PM
Skinny's Avatar
Skinny
the car is MFI still do you think the clocks have had it or is there anything I can try before I get a new set?
Martin
Old Dec 19, 2012 | 12:12 PM
martysmartie
Check the wire on the coil (green) that or usually the cluster is a PCB affair, and the tracks may have corrosion etc.
Martin
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
