Passo side drive shaft removal- help needed ASAP
Guys,
Out here trying to remove passo side drive from the box, shud it just pull out like the drivers side, I have the top nut on the suspension undone, arb and control arm are off, cheers Simon
Same as drivers side; like all engineering problems like this you just need more leverage
K cool the shock is still in the hub, shoud there still be enough? My engineering skills usually consist of lumping until it moves but I was not sure and didnt want to break it
raging now. The rhs was no problem, the lhs was a nightmare. Arb won't come out of control arm, track rod end had to be cut off, broke my alley key taking off the top mount!
