over boosting
Old Oct 17, 2012 | 06:47 PM
mr west's Avatar
mr west
Default over boosting
Hi all i took the rs for a drive today for the first time since fitting the zvh all fine other than its over boosting big time no matter if the bleed valve is all the way in or out.
what could be the problem?
Old Oct 17, 2012 | 07:10 PM
liam-rst's Avatar
liam-rst
shit happens
Take it you have deleted the amal valve? Possible wrong adjustment on actuator? Is it mfi or efi?
Old Oct 17, 2012 | 07:37 PM
mr west's Avatar
mr west
The turbo set up is just as it was on my cvh. Its on mfi mate. Could the actuator or wastegate be stuck?
Old Oct 17, 2012 | 07:52 PM
liam-rst's Avatar
liam-rst
shit happens
Try adjusting the actuator, and while the arms off check the wastegate moves freely as it would have to be stuck closed to overboost
Old Oct 17, 2012 | 07:56 PM
mr west's Avatar
mr west
Ok will do thanks, is it shorter or longer for less boost?
Old Oct 17, 2012 | 08:09 PM
liam-rst's Avatar
liam-rst
shit happens
Out mate, start off ith the actuator wound in so it needs pulling onto the wastegate arm (approx half a hole) and then start by winding it out turn by turn and see if lowers the boost, make sure the actuator is not seized either as this won't allow the wastegate to open
Old Oct 17, 2012 | 08:18 PM
mr west's Avatar
mr west
Cool, will get on it when I get some time. Thanks for the info
Old Oct 17, 2012 | 08:30 PM
liam-rst's Avatar
liam-rst
shit happens
No problem mate good luck
Old Oct 17, 2012 | 08:43 PM
mk1trb's Avatar
mk1trb
Boost Junkie
have you checked the hoses arent split or popped off
Old Oct 17, 2012 | 08:57 PM
liam-rst's Avatar
liam-rst
shit happens
Would have thought with a split or loose hose he would have lost boost and have running probs
Old Oct 17, 2012 | 10:12 PM
Canada1's Avatar
Canada1
The boost pressure opens the waste gate to control boost. Take the hose off and see what happens - max boost the turbo can put out.
Cheers.
Old Oct 17, 2012 | 10:17 PM
liam-rst's Avatar
liam-rst
shit happens
this is true but only if were talking about the pipe between the turbo and actuator but I would still expect running problems at idle
Old Oct 18, 2012 | 02:57 PM
mr west's Avatar
mr west
vac hose had split where it joins the turbo, not over boosting now but need some adjusting as its only boosting to half a bar now.
Old Oct 18, 2012 | 07:36 PM
liam-rst's Avatar
liam-rst
shit happens
Glad you got it sorted mate, id get it set up now though as bleed valves are a bit dodgy
Old Oct 18, 2012 | 07:57 PM
mr west's Avatar
mr west
ive taken the bleed valve out and gone from actuator to turbo. yeah i'm just ironing out the few small issues then its off to power engineering for the 5th injector controler box to be wired in and a full set up. o and need to upgrade my gearbox first lol
Old Oct 18, 2012 | 08:15 PM
mk1trb's Avatar
mk1trb
Boost Junkie
glad i could help mate
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
