Escort RS turbo S2 MFI
~Hello,
what I need to do, to increase Boost Preassure with chipped ECU?
i can use a manual boost controller? or a Wastegate -31? it will work with manual Boost controller? how I install this?
with a chipped ECU the only thing that i need to change to get more power is the boost Preassure? i dont need adjust fuel mixture or anything?
thanks
Best regards
thanks
Best regards
you'll need a -31 actuator, preferrably genuine garrett and yes you will need the fueling adjusting to suit. a full setup by a professional who knows MFi well is the best, most hassle free way to go as it can be a pain to setup.
a word of caution though, if all you do is bump the boost up the engine will last all of 30 seconds at best as it'll run lean and destroy itself. make sure it's done properly if you're not competant with the ke jetronic system pal.
do you know it will the the setup on the fuel system ?
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
