help brakes related
help brakes related
need some help, basiclly i fitted 300mm discs/mk3 mondeo calipers all new/refurbed and the bastard wont bleed up. i inspected the m/c were it bolts up to the servo and noticed it was leaking. my question is will the 23 id m/c be upto the job of the big calipers and if not is there a readily available bolt on replacement? i have a mk5 servo/mc that i was kindly given however, its a faff to fit so im looking for the easier option.
how much mate? im going to try motorfactors tommorow, ideally want to get the brakes done asap. properly pissed me off, 3hrs covered in brake fluid for....... fuck all
ill keep it in mind if thats ok mate. im t'other side in nth lincs otherwise id collect. ill see if i can track one down in the morning.
right ive sourced a m/c. prob is i have a choice of 2. 23mm id or a 28mm. i know the 23 will work ok with mk3 modeo calipers but would the 28mm be better or overkill as im still using rear drums. thanks for the input
