1.8zvh cossie management crank sensor bracket???????
Hi there as title really got the cam cover off a 1.8cvh sierra with the sensor in but as im zvh it fails to line up with the holes any one made a custom bracket for this???? any help will be appriciated
cheers
rob
cheers
rob
P8 Managed S1 with ALS
Im sure Jano will be able to sort this out but if your running a zetec bottom end why would you need to run a sierra cvh bottom pulley set up ? Surely the zetec flywheel sensor set up wouild be a much easier way to go ?
So in effect you omly need the phase sensor set up for the cam pulley ?
most management uses a 36-1 trigger pattern so you use efi flywheel and fit the standard sensor in the block, burton power do a kit that mounts on the bottom pulley if you dont want to go that way you woud then need to fit a trigger wheel to the pulley,
Spanner monkey
I spoke to Jano to see if he did any off the shelf for the zetec bottom end but he said there is 4 different pumps which have very slightly different castings making it difficult just to have one made in multiple numbers.
I ended up making this one out of 3mm steel plate then using some ally angle to hold the sensor. The ally angle has slotted holes allowing gap adjustment.
03-11-2015 04:08 PM
