For anyone interested in a Zetec turbo conversion.
Old 02-04-2014, 10:24 PM
  #121
marky_g
Fleet Manager
marky_g's Avatar
So a std st170 bottom end will take 350? I think I might have to build a zetec!!!!
Old 03-04-2014, 08:59 AM
  #122
Karlos G
Balls Deep!
Karlos G's Avatar
Originally Posted by rsmark86
dubbs44 machined up a little conversion plate in a few minutes that made his frst tps bolt straight to the blacktop inlet
No need, OFAM can use any TPS and other sensors too.
Yes!
Old 03-04-2014, 10:08 AM
  #123
marky_g
Fleet Manager
marky_g's Avatar
Yes!
Omg omg omg omg!!!!!! I think this is a plan then!
Old 03-04-2014, 10:02 PM
  #124
Karlos G
Balls Deep!
Karlos G's Avatar
lol good man!
Old 05-04-2014, 03:20 PM
  #125
leers85
leers85's Avatar
love this conversion, top work!
may have to try this on my mk1 focus.
Old 05-04-2014, 04:33 PM
  #126
higgsy91
Zetec Turbo Baby Yeahhhh
higgsy91's Avatar
Question...
Just about to buy megasquirt and install parallel to my focus ECU. Do I need to buy the fan outputs or will the standard ECU control this fine still, as it still has the CTS reference?
And if I were to go ahead and buy them could I splice them in together with the old loom or would I need diodes to prevent damage to the ECU?
Cheers!
Old 05-04-2014, 05:44 PM
  #127
Mk4 Rick
Mk4 Rick's Avatar
What cr will you get with this st170 bottom end and head? would you use a stock head gasket
Old 06-04-2014, 10:52 AM
  #128
RS-Rikki
RS-Rikki's Avatar
No use a 1.8mm head gasket
Old 06-04-2014, 11:15 AM
  #129
studabear
studabear's Avatar
Are they available again?
Old 06-04-2014, 11:49 AM
  #130
primedog
primedog's Avatar
As it's been mentioned about old ford wiring being pony etc I'm deciding to go with megasquirt ms2 and just start with fresh wiring, which also entitles me to use all blacktop inlet sensors etc. Can I use an escort RS turbo air temp sensor as il hav plenty of them about me.
And are the vxr injectors literally plug in and play, no adaptors or cups to sit them in? I do hav some Nissan 200sx injectors (330's or 360's I think) can I just use them? If so il chuck them in the inlet and bolt on a frst fuel pressure reg, then inlet goes on!! Management will then be purchased!! 👍
Sorry bout all the questions but I'm in final stages now and if I don't need to pay out for vxr injectors as iv got 200sx and ain't gotta buy air temp sensor as can use RS turbo one then il be ordering management!
Massively appreciated!!!!
Old 06-04-2014, 01:17 PM
  #131
Mk4 Rick
Mk4 Rick's Avatar
What compression ratio would i get using this gasket with the st170 bottom end and the blacktop head
Old 06-04-2014, 01:34 PM
  #132
studabear
studabear's Avatar
read the first posts of the thread.
Old 06-04-2014, 01:50 PM
  #133
xrmalin
xrmalin's Avatar
Yes they are as my mate bought one last week from ford to do this very conversion.
Old 06-04-2014, 09:44 PM
  #134
RS-Rikki
RS-Rikki's Avatar
Doing this conversion at the moment hopefully have it done this week so I'd of done it in 2 weeks that includes sourcing parts
Old 06-04-2014, 09:45 PM
  #135
RS-Rikki
RS-Rikki's Avatar
I got one of ebay 145 quid
Old 06-04-2014, 09:46 PM
  #136
RS-Rikki
RS-Rikki's Avatar
Think your better of using vxrs I do have a set actually for sale
Yeah use rs turbo sensor put a boss in the solid boost pipe
  #137
studabear
studabear's Avatar
Ouch £145.
Have you got the engine in the bay yet?
Old 06-04-2014, 09:48 PM
  #138
studabear
studabear's Avatar
Just to add I used cossie air and water temp sensors as they easily sourced and the data for the management is on big turbo.
Old 06-04-2014, 09:53 PM
  #139
RS-Rikki
RS-Rikki's Avatar
Ouch £145.
It is a pec one but only thing I could find
Hopefully Wednesday I'll post picks it's making the inlet fit and wire it up I'm worried about :-/
Old 06-04-2014, 10:05 PM
  #140
studabear
studabear's Avatar
I advise you mod the ledge on the inner wing where the engine mount attaches to make some clearance for the timing belt guide pulley.
Old 06-04-2014, 10:16 PM
  #141
RS-Rikki
RS-Rikki's Avatar
Ledge what you mean u got any photos?
Old 06-04-2014, 10:25 PM
  #142
studabear
studabear's Avatar
Will have a look on pc tomorrow
Old 07-04-2014, 04:53 PM
  #143
xrmalin
xrmalin's Avatar
Ouch indeed I think my mates was only £70 straight from ford
Old 07-04-2014, 07:38 PM
  #144
studabear
studabear's Avatar
This is before the ledge was trimmed. The gap between the tensioner and body closed further when I fitted the vibratechnics gearbox mounts.
You wanna cut a bit out like this. Can't get a actual picture at the minute.
Hope this helps.
FloydH (30-09-2019)
Old 07-04-2014, 08:20 PM
  #145
HaggisTurbo
HaggisTurbo's Avatar
Wow that is pretty close lol
Old 07-04-2014, 08:33 PM
  #146
RS-Rikki
RS-Rikki's Avatar
Shit me!!
Ok I'm on it
Right on the inlet there's a like a metal pipe that runs off with a flange do I just block that off?
Anyone got any pics of there sump mods gotta try guess where the 2 drain plugs for oil return ect
Old 07-04-2014, 08:40 PM
  #147
studabear
studabear's Avatar
My rear breather turn was very close to the driveshaft so I had to have a 90degree bend as soon as the hose attaches.
Old 07-04-2014, 08:42 PM
  #148
studabear
studabear's Avatar
Just to add my pictures are just how I did it.
Old 07-04-2014, 09:05 PM
  #149
RS-Rikki
RS-Rikki's Avatar
Ok cool any idea on the metal pipe on the inlet?
Old 07-04-2014, 09:19 PM
  #150
studabear
studabear's Avatar
What inlet?
Old 07-04-2014, 09:23 PM
  #151
RS-Rikki
RS-Rikki's Avatar
Mondeo there's like a metal elbow? What did u block the holes up with?
Old 07-04-2014, 09:40 PM
  #152
studabear
studabear's Avatar
Stick a picture on. Mine had a couple i blocked, they had pipes on them i blocked them with bolts pushed in with rtv sealant and hose clips if my memory serves me well. The other outlets I used for boost gauge and map sensor.
Old 07-04-2014, 09:43 PM
  #153
RS-Rikki
RS-Rikki's Avatar
Am I right in thinking silvertop rocker covers fit? Does the rs one fit? Or even the st170 has a breather pipe just want the extra so can use a bailey oil breather
Old 07-04-2014, 09:50 PM
  #154
RS-Rikki
RS-Rikki's Avatar
Old 08-04-2014, 06:39 AM
  #155
studabear
studabear's Avatar
Silver top fits,read through entire thread you will see mine with extra port added. Pipes in your picture i didn't have, they look like fuel pipes? I used focus rs inlet, throttle body is bigger fuel pipes are diff too I think?
Old 08-04-2014, 08:11 AM
  #156
RS-Rikki
RS-Rikki's Avatar
Is there any guides on fitting a cam belt never done it before I know usually u can lock them ect but different bottom end to head ect little bit daunting all this money could go down the pisser in a instant :/
Old 08-04-2014, 08:20 AM
  #157
studabear
studabear's Avatar
Haynes manual for focus or mondeo or autodata will sell individual info for about £8. I advise you buy the timing tools for blacktop zetec about £12 on ebay.
Old 08-04-2014, 08:24 AM
  #158
RS-Rikki
RS-Rikki's Avatar
Yeah but that's just lock off tools surely the cams need to be position properly for the bottom end
Old 08-04-2014, 09:21 AM
  #159
studabear
studabear's Avatar
If everything is locked in correct position then it is timed up. If your not sure what you are doing find someone who does and get them to help you.
Old 08-04-2014, 09:22 AM
  #160
studabear
studabear's Avatar
You lock the crank aswell as the cams.
Quick Reply: For anyone interested in a Zetec turbo conversion.
